Water tanks (Inox Vs Galvanized steel) - Page 2 - SailNet Community
post #11 of 11 Old 10-27-2012
Re: Water tanks (Inox Vs Galvanized steel)
I cut large access ports in my 4 aluminum water tanks( a total of 1500 liters) and laid down a fiber glass /epoxy tank inside including both sides of existing baffles . One at a time because it was a bear of a project and potable tank 'gelcoat' needs to go on fairly fresh substrate.Welded a 3/16 th by 2 Al inch strip around the cut out lid and tapped threads into tank to take the holddown bolts. Neoprene gasket and Bob's yer uncle .Other than working upside down with a full face mask and extension cord for days, nothing to it. and the finished result was definitely worth it.
Capt Len is online now
Tags
galvanized steel , inox , water tanks
Splits in stainless steel water tanks Erino Gear & Maintenance 0 04-25-2012 12:41 AM
Cleaning galvanized water tanks Tmcboat Gear & Maintenance 2 08-12-2010 04:55 AM
Clean water tanks, well water josrulz Gear & Maintenance 14 06-14-2010 06:39 PM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
water tanks kix428_2000 Gear & Maintenance 5 06-17-2001 05:55 AM
