Hi All -
I sail a 30 yr old CAL 39 MkII (Jensen Marine) that I just bought this past July. One of the things needed is for me to replace the old, cranky manual
windlass with an electric (12V) type. The existing
windlass is mounted in a
line locker directly below the foredeck triangular
hatch cover. I'd like to mount the new unit on top of that
hatch cover at deck level by reinforcing the
hatch above and below with starboard or another material, but at least one person has said that the
hinges on the
hatch won't take the load and advised against it, saying I should mount it below deck in that
line locker above the chain locker that the boat's original design apparently called for. My engineering analysis is that the direction of the chain/rode load on the
windlass will be
in the plane of the reinforced hatch cover and therefore not tending to pull out the
hinge mounting screws. Any thoughts on positioning and whether a vertical or horizontal
windlass would work better?
Thanks to all you more experienced salts out there for taking time to give me your opinions.
Mark
