need help to identify elec windlass! - SailNet Community
post #1 of 8 Old 10-25-2012 Thread Starter
Dufour 27 Newb
hello all!
is anyone able to recognise the make/model of this electric windlass please?
thanks
jaybeegee is offline
post #2 of 8 Old 10-26-2012
PhilipStevens's Avatar
Send a message via Skype™ to PhilipStevens
Re: need help to identify elec windlass!
What is the name on the switches? Is it Markwell?
If so, it could be Australian
If it is Maxwell, it could be part of Vetus and be Australian or New Zealand
regards,
Philip.
PhilipStevens is offline
post #3 of 8 Old 10-26-2012
chucklesR's Avatar
Open the locker and look at the motor. It will have a make and model plate or sticker right on it.
My off hand guess, a Maxwell, looks to be a 1500 or so - but why guess when you can look and see?
chucklesR is offline
post #4 of 8 Old 12-03-2012 Thread Starter
Dufour 27 Newb
No names on the switches unfortunately - where would they typically be? Would dismantling help to identify the switch?
post #5 of 8 Old 12-03-2012 Thread Starter
Dufour 27 Newb
thanks for that! believe it or not there is no make or model!
But your tip did highlight a problem (see below) which I have since resolved with a wire brush and a good dose of hammerite paint applied to the rust areas.
Here is the pic of the motor before the paint job!
thanks for your time.
J.
post #6 of 8 Old 12-03-2012 Thread Starter
Dufour 27 Newb
Sorry take that back - switches are in fact Maxwell!
post #7 of 8 Old 12-03-2012
chucklesR's Avatar
Glad I could help, sometimes you never know what is just below the surface.
Second suggestion - epoxy all that wood! - Start with a CPES (clear penetrating epoxy sealer - I like Smith's brand) and add a coat or three of West system after that's dryed.
Especially make sure you get it good around the hawse hole (where the chain goes through).
post #8 of 8 Old 12-03-2012
Possibly not relevant, but my Dufour 35 came from the factory with a Goiot manual windlass, as well as mostly Goiot hardware, hatches, etc. All French of course, and very nice stuff back then. Not sure if they changed suppliers over the years. Not a lot ov visible logo's on their pro0ducts, if I remember right.
Mike sullivan
1985 Marshall 22 catboat
mbsl98 is offline
Tags
windlass
Elec-tricky-ty Dilema - Battery Wiring gitanopw Electrical Systems 6 10-11-2012 10:09 PM
Elec fuel swith kale Gear & Maintenance 14 11-06-2008 01:04 PM
Prop shaft elec generation captainchetco Gear & Maintenance 0 05-16-2007 08:20 PM
Looking for Elec. panel labels grfoggynotion Gear & Maintenance 3 01-05-2007 09:55 AM
Can anyone identify this rleslie Gear & Maintenance 2 04-26-2005 06:35 PM
