Like Tree4Likes
  #11
Old 10-26-2012
msmith10's Avatar
Junior member, rest old
msmith10 is on a distinguished road
Re: Does DOW 795 ever cure, bond or dry?
Dow 795 is great stuff, but definitely has a shelf life. It's an architectural adhesive/sealant for glass. I've found it to be very strong, highly elastic. When it's past it's shelf life, though, it has a very funny cure. If it's too old, you can tell as soon as you apply it- it feels more like polysulfide than silicone.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
  #12
Old 10-26-2012
anerussis's Avatar
anerussis is on a distinguished road
On the tube is stamped Oct 10 -- so i assume Oct. 2010 -- is it too old? Will it eventually to the job or do I need to re-do the windows?
Also I had just wrapped the nozzle of the leftover tube with some saran wrap and when I tried it early this morning the stuff came out easily as if I had just broken the seal - is this normal?
Years from now you will be more disappointed by the things you didn't do than the ones you did do.
~Mark Twain
  #13
Old 10-26-2012
anerussis's Avatar
Just found the Dow specs for the Dow 795 - and now I realize whats happening ---" In totally confined joints (the sealant
requires atmospheric moisture for cure)"
In using this Dow 795 the more is not better- My window situation is because I believed the opposite and pumped as much of this stuff as I could in the joints. Also I think the reason my small test pieces did not bond is because the bead I applied was in the center of the pieces and sitting at the corner of my office desk and since there was no moisture present the silicone did not cure.
I would include the specs in pdf format but I don't know how.
~Mark Twain
  #14
Old 10-26-2012
GaryHLucas is on a distinguished road
I believe you got some old stock and it will never cure remaining like silly putty forever. I got sold old stock as well for my windows and contacted Dow. They told me never to use 795 beyond its use by date. Oh what fun peeling all that stuff off! The vendor gave me fresh tube and it cured with no problems. Sorry for the bad news.
  #15
Old 10-26-2012
flyingriki's Avatar
flyingriki is on a distinguished road
Originally Posted by DRFerron View Post
I'm going to slide this thread into a more appropriate forum.
Wow! The moderator is a BABE......how nice!
  #16
Old 10-27-2012
mitiempo's Avatar
From Select Plastics - the largest hatch remanufacturer in the business - temp has to be above 50 F for the entire 21 day cure.
Faster likes this.
Brian
  #17
Old 10-27-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Not only that - SHE hunts down & buys the boats in her family. I think her husband struck more gold than Sutters Mill there.
Edit: Quote:
We're pretty much doing the same with our next boat. He gives me his list of requirements, I find the boat and he writes the check. Works perfectly for us.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #18
Old 10-27-2012
MikeinLA's Avatar
MikeinLA is on a distinguished road
PLEASE don't ever use the phrase "DOW 795" in a title again. I haven't checked my stocks in a few weeks and I almost had a stroke.
Mike
SloopJonB likes this.
  #19
Old 10-27-2012
SimonV's Avatar
Wish I never found SN!
SimonV will become famous soon enough
Dow 795 is perfect for through deck chain plate seals as it never truly cures . If using it in a place where someone may step or touch, I found a sprinkling of talc over the out side helped.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location New Caledonia/Vanuatu
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcohlic
You may post attachments
You may edit your posts
Epoxy won't cure. Help! kwaltersmi Gear & Maintenance 13 09-14-2011 01:18 AM
Sailing for a cure Slayer General Discussion (sailing related) 0 08-12-2008 11:06 PM
Sea Sickness - Cure? Tucks Learning to Sail 87 03-31-2008 07:16 PM
To bond or not to bond, that is the question! wildcard Gear & Maintenance 2 12-04-2006 11:33 AM
To bond or not to bond? maxim_rfeld Gear & Maintenance 5 01-27-2005 01:58 PM
SEO by vBSEO 3.6.1
