Help with topside paint repair - Page 3 - SailNet Community
 1Likes
post #21 of 26 Old 11-03-2012
Senior Moment Member
SloopJonB's Avatar
Re: Help with topside paint repair
Originally Posted by malyea View Post
- roll and tip with white imron, probably two coats to help 'fill' the scrape
The two part paints I've seen used had no "fill" ability like regular paints - they showed every defect in the substrate.
SloopJonB is offline
post #22 of 26 Old 11-06-2012 Thread Starter
Thanks for the tip on "lack of fill ability" of the two part Imron. Since I'll be feather sanding the scraped paint edges smooth and there's no gouges in the underlying gelcoat/fiberglass...I wonder if I'll get a little bit of "buildup/fill" from the primer.
As the photo shows the old paint is about 1/64 - 1/32 thick...
malyea is offline
post #23 of 26 Old 02-02-2013
Asleep at the wheel
jimgo's Avatar
How did this turn out?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #24 of 26 Old 02-03-2013
tommays's Avatar
That is a really difficult repair that would Not even be possible even in and autobody shop IF the car did not have doors and other seems to break up the job
Even if it was gelcoat the person would have to be REALLY GOOD
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #25 of 26 Old 02-03-2013 Thread Starter
Still a work in "progress"....
I've sanded the old grey primer down to the old under lying gel coat and from 50' (without glasses) you can hardly see the scrape. I talked with the local IMRON dealer and he recommended DuPont NASON instead of DuPont IMRON.
Waiting on warmer weather before proceeding and still not certain which paint I'll use...99% sure the previous paint is IMRON and he says the two are compatible but NASON (with activator) is much less expensive plus he says he can hardly get the IMRON that was used several years ago...
I'm still challenged by the fact that I can't perfectly "feather sand" the old paint scrape edges flush so unless I "build up the scrape" with paint/primer/filler/epoxy - I'll be left with an "edge" around the newly painted scrape of about 1/80 inch deep...
...and then of course there's the issue of color matching....
.....that's why the better course seemed to go sail the Outer Banks and wait for spring - maybe even this spring ;-)
malyea is offline
post #26 of 26 Old 02-03-2013
Asleep at the wheel
jimgo's Avatar
Sounds like a good plan!
Good luck with the repair.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Seafevers topside paint tommays Cal 3 04-02-2013 06:19 PM
Non Skid topside paint? BreakAwayFL Gear & Maintenance 4 03-19-2012 10:00 PM
Petit topside paint dpayne Gear & Maintenance 4 08-09-2007 12:52 PM
topside paint stevenm Boat Review and Purchase Forum 1 09-23-2002 10:00 AM
Topside Paint lifespan mrb2222 Gear & Maintenance 4 08-26-2002 06:44 PM
