Seacocks - SailNet Community
post #1 of 10 Old 10-29-2012 Thread Starter
Seacocks
Question about the little screw on the side of the body of bronze, flanged seacocks. Is that for lubrication or for draining water for winterization? Thanks for your help.
Ajay73 is offline
post #2 of 10 Old 10-29-2012
Chastened
Ajax_MD's Avatar
Re: Seacocks
That's for draining for winterization.
If these are bronze, tapered cone seacocks, you remove the cone from the body, lap them with lapping compound, then you lubricate them.
FYI- Groco made these wierd seacocks with a rubber cone. These have a T-handle on the end of the body to swell the cone once you've positioned the valve to open or shut. (Just in case you have these)
1981 Tartan 33 #168
Ajax_MD is offline
post #3 of 10 Old 10-29-2012
Señor Member
PorFin's Avatar
Re: Seacocks
Both -- you can drain the water from a closed seacock through the hole; or if you insert a zerk fitting, inject grease into the seacock.
PorFin is offline
post #4 of 10 Old 10-29-2012 Thread Starter
Re: Seacocks
Thanks for the reply. If you open the seacock with the boat out of the water does that eliminate the need to use the drain/lube hole to drain water. In other words, is there possibly water in the seacock body that is somehow trapped and can only get out through the drain hole?
These seacocks are Apollo brand. Bought them at West Marine.
Ajay73 is offline
post #5 of 10 Old 10-29-2012
Maine Sail's Avatar
Re: Seacocks
Spartan for example specifically advises against this. Those screws in Spartans are specially made of the same alloy, 85-5-5-5 bronze as the rest of the seacock. There is no such animal as an 85-5-5-5 bronze grease zerk thus installing one introduces dissimilar metals into the equation... They also strongly advise against using that screw for bonding. They are drain plugs for intended winterizing..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #6 of 10 Old 10-29-2012
Maine Sail's Avatar
Re: Seacocks
You have ball valves and they should ideally be drained.... Opening and closing does not always allow them the drain. It should, but does not always.. With tapered cone they do drain but with ball valves not always..
______
post #7 of 10 Old 10-29-2012 Thread Starter
Re: Seacocks
MS, could you use the grease zerk, grease the valve and then remove the zerk and put the screw back in?
Ajay73 is offline
post #8 of 10 Old 10-29-2012
Señor Member
PorFin's Avatar
Re: Seacocks
That's the idea. As MS said, leaving a zerk in there permanently is asking for trouble.
PorFin is offline
post #9 of 10 Old 10-30-2012
Maine Sail's Avatar
Re: Seacocks
It does not do a proper greasing and lubing of a tapered cone valve and standard ball valves don't require greasing. It might be a short term band-aid for a tapred cone but they still require dissasembly, cleaning lapping and greasing ever few years.
______
post #10 of 10 Old 11-04-2012 Thread Starter
Re: Seacocks
I opened the drain nuts but didn't get any water draining out on its own. I twisted up a piece of paper towel and and inserted it into the drain hole and there was a bit of water in there, not very much at all. I would assume that what water is in there is not very much. Correct?
Ajay73 is offline
Seacocks SkywalkerII Gear & Maintenance 12 03-16-2012 06:36 PM
Seacocks SloopJonB Gear & Maintenance 1 01-01-2012 10:16 PM
seacocks again redhead78 Gear & Maintenance 2 01-18-2010 07:59 PM
Seacocks chris_gee Gear & Maintenance 10 01-17-2009 02:57 AM
Seacocks - Again MeCaptainBinky Gear & Maintenance 13 10-19-2008 11:10 PM
