Woodworking advice needed - SailNet Community
post #1 of 14 Old 10-29-2012 Thread Starter
Barquito
Barquito's Avatar
I have some water damage to the top corner of by bulkheads. This is from leaking chainplates (now fixed). The chainplates connect to separate knees, so, I'm not too worried about structural stength. My question is, what is the technique for replacing just that small (maybe a square foot) section? I'm also not going to get too worried about matching the existing veneer.
Valiant 32
Barquito is offline
post #2 of 14 Old 10-29-2012
Re: Woodworking advice needed
If it's just plywood a Dremell occelating can easily cut out a chunk right up to the cabin top/sides. Half inch (filled) epoxy glue holds the newly fitted piece . with care the veneers could look decent If it's glassed to the cabin its a bit off prep work with a chisel and mallet. At least you'd be working out of the weather.
Capt Len is offline
post #3 of 14 Old 10-29-2012
Tim R.'s Avatar
Photos would help. Can you repair structurally and then cover with some solid teak trim?
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #4 of 14 Old 10-29-2012
Senior Moment Member
SloopJonB's Avatar
Yeah - if the stained/damaged piece is the right shape you could make a "hanging knee" shaped piece of trim to cover it.
See if you can find pictures of the main bulkhead of a Yankee 38 - they had an arrangement sort of like that.
SloopJonB is offline
post #5 of 14 Old 10-29-2012
emoney's Avatar
It really is all about the photos in this case. Plus, how important is the finished look? Hard to imagine, but if at least one side of it "won't show" so-to-speak, you can use epoxy and then put a support strip that lays across both sides of the joint on the back side. How thick is the area in question? Any chance it's thick enough to cut a scarf joint, or no? Again, pics would help a ton.
emoney is offline
post #6 of 14 Old 10-30-2012 Thread Starter
Barquito
Barquito's Avatar
Can't get out to the boat to take pictures until this weekend. Actually, if it gets blasted off it's mooring in Milwaukee (thanks Sandy, we are getting 48kt gusts), then this thread will be moot.
I think is is 3/4" ply. How would I go about cutting a scarf joint with the majority of the bulkhead still in place? I think once I make the repair I will just put a "knee joint" like piece of trim over the patches. OTOH, if the very corner of this bulkhead doesn't lend much to the overall strength and stiffness, would it be crazy to just cover it, and not repair?
Valiant 32
Barquito is offline
post #7 of 14 Old 10-30-2012
emoney's Avatar
Odds are you'd need to remove it and then replace it to cut a scarf joint. A lot depends on how good you are with a small skill saw, and do you even have access to it. If it's not part of the structural integrity and it won't look terribly odd, nothing's stopping you from not repairing it. As a matter of fact, if it fits both those criteria you always have the option of doing that to the opposite side to make them match. Of course, having said that out loud, usually the corners tend to bear a lot of the load, if the bulkhead is, in fact, designed to add stiffness. How big of a piece is the entire bulkhead? Not something you want to just replace the entire thing?
emoney is offline
post #8 of 14 Old 10-30-2012
Why a scarf joint? If that part of the bulkhead is structurally important, then you need to install your patch with a joint that is as strong as the bulkhead was before you cut it. You also need to join the patch to the cabintop/cabin side in the same way that the original piece did--probably tabs.
A scarf joint's strength will depend on precise, accurate saw cuts. It will also require the right amount of the right glue, and good clamping. You probably can't do it with the bulkhead in place unless you're really good with hand tools--really sharp hand tools. Even then, I'd question it's strength. I doubt you'll have clearance for a skill saw, and if you do, you better know how to use it accurately. Any fenceless type of power saw that relies on a steady hand, forget.
If you don't care about looks, maybe use tabbing all around. After all, it's strong enough to bond the bulkhead to the boat. And it won't require precise cutting. If looks are important, buy some nice plywod, tear out the bulkhead, use it as a template for a new one and tab it in place. It's probably going to be easier in the long run. Or, make an ugly-but-strong patch and cover the whole bulkhead with door skin or something else relatively inexpensive.
If you patch, cut the patch first. Use it to carefully trace the outline that you want to excise from the bulkhead.
VallelyJ is offline
post #9 of 14 Old 10-30-2012
My repairs always look like repairs. It would just "ugly" up the boat if I tried to patch the plywood.
With the proper amount of Capt'n & Coke, try to visualize a rework of the area. Its probably a little dark inside the Bristol, so using white formica, a half panel coming down the bulkhead to just below the portlights, trimed in teak would cover the repair and brighten up the interior. Adding a small shelf (or 19" flat screen) on the white panel would even make the space usable.
Also, because this would cover the repair, you can follow the old woodworker's guide, "When in doubt, make it stout".
Hope your boat came thru the blow okay.
Jurgy
Jurgy is offline
post #10 of 14 Old 10-30-2012 Thread Starter
Barquito
Barquito's Avatar
Its probably a little dark inside the Bristol.
Hey, I resemble that remark.
I like the getting-buried-in-a-pile-of-finished-wood look of the interior of older boats.
I will have to take a closer look to see where the tabbing is. I know it is strongly attached at the bottom. The spot in question is just under the area where the dog house meets the deck. So far, there are no concerns about stiffness, as this boat will probably never meet anything more than Great Lakes chop (OTOH, that is 25'ers today). So far, there are no concerns about stiffness.
Valiant 32
Barquito is offline
Advice needed Sixpoint General Discussion (sailing related) 11 05-05-2011 12:21 PM
Bandsaw trick, Well we don't have a woodworking forum! deniseO30 Gear & Maintenance 18 01-23-2011 09:08 PM
More RIB Advice Needed danielgoldberg Boat Review and Purchase Forum 8 12-28-2008 10:54 AM
woodworking on boats langousta Gear & Maintenance 6 06-02-2006 01:01 PM
