Like Tree3Likes
  #1
Old 10-30-2012
bradway5 is on a distinguished road
replacement flooring
Due to some water damage, i had to rip out the teak and holly interior flooring (plywood). Now with it being pretty expensive to replace with teak and holly again, i was hoping to just lay something quick and inexpensive in the meantime. Any recommendations? I've seen some photos of what it looked like a home vinyl flooring. It's not a long term solution, but looking to get a few years out of it so i can knock out some higher priority projects. Thanks
Rich
  #2
Old 10-30-2012
Re: replacement flooring
You could check these guys out.. should be less expensive but may not be 'cheap'.
Marine Teak & Holly and Boat Flooring | PlasTEAK & PlasDECK
Otherwise any plywood based floor could be installed, using the old as a pattern. Epoxy seal it and paint it, or apply a covering like that available above. You could even get clever with masking tape and paint it in a 'pseudo teak/holly' pattern.
I would not suggest carpet.. it's a dirt/mold/moisture/mildew magnet.
EDIT.. just remembered a friend did a real nice job with plywood substrate and bamboo flooring.. looks great
  #3
Old 10-30-2012
chucklesR's Avatar
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
You can always go with plywood (seal it with epoxy first, CPES is good for that) - then lay some relatively inexpensive engineered flooring on it. Cherry should look good, but mahogany engineered stuff cost the same.
They make teak and holly looking vinyl, but why fake it.
Read, laugh, learn, or just enjoy
  #4
Old 10-30-2012
ABH3 Boyer is on a distinguished road
I used a vinyl product made by Veranda. It can be purchaced at your big home improvement store or a well fitted lumber yard. It came in sheets 4ft x 8ft and in 1/2 & 3/4 inch thickness. It wont rot, it floats, dosn't absorb water, is light weight and is almost indistructable. The down side is I got it in white and before I added the non-skid it was getting marked up by peoples shoes so I rolled on grizzly grip. after a season of hard use it still looks new. The marks always came off the white, just a nuisance. I think I paid around $85 per sheet. It cuts almost exactly like wood and can be shaped when heated.
replacement flooring-cheektowaga-20120521-00518.jpg   replacement flooring-cheektowaga-20120425-00462.jpg
chucklesR likes this.
  #5
Old 10-30-2012
JimMcGee's Avatar
JimMcGee is on a distinguished road
You have to be careful about using Home Depot type flooring. It's made for indoor use and may have serious problems with the temperature extremes you see in a boat.
This product is made for the marine environment as is PlasTeak. NU Teak Decking Inc - Teak and Holly Marine Flooring
The biggest difference is the PlasTeak is sold in sheets, which can be a bit of a bear with all the cuts and curves in a boat. The NuTeak is sold in strips. Make a mistake with one strip and it's not a big deal. Make a mistake with a sheet and you either live with it or replace the whole sheet.
95 C30 Island Time
If more of us valued food and cheer and song above gold it would be a merrier world.” ― J.R.R. Tolkien
  #6
Old 10-30-2012
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
I can't tell from your profile where you are located. My suggestion below would only work for you if there are marine craftsmen located near you.
Last Winter I replaced the part of my cabin sole that had warped. It may be too expensive to scale up to as much as you need, but you can decide that for yourself. I bought some 1/4" teak and holly remnants from a local shop at minor discount, epoxied them to 3/4" marine plywood, cut the pieces to size, and sealed the bottom and edges with epoxy. The two pieces were each about 2 sq feet. This approach was a lot less expensive for me than buying a half (4'x4') T&H sheet and another of marine plywood on the web, even with the extra cost of using a flexible epoxy like Waste Marine's G/Flex 650 so that it flexes when the wood flexes.
Tom
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
  #7
Old 10-30-2012
Wow, Jim. That Nu-Teak product is gorgeous! Do you know who sells it and how much it is? A buddy's boat could use some of that and I'd like to point him in the right direction.
T. P. Donnelly
Pasadena, MD
  #8
Old 10-30-2012
JimMcGee,
Have you seen this product before? Does it look like a sheet of plastic or rubber? The stuff definitly looks like something up my alley.
  #9
Old 10-30-2012
overbored's Avatar
overbored is on a distinguished road
Nu teak , Plas teak and Lonwood marine are all vinyl for interior floors, come in 6' wide rolls and are 2mm thick. about $45 a running foot. nu teak and plasteak make an exterior decking that comes in strips and is about 5mm thick. about the same price as real teak plywood. the only one that looks like the real thing is the lonwood. real teal and holly plywood cost about $200 a sheet. most of the new boats are coming with laminate flooring
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
  #10
Old 10-30-2012
justified is on a distinguished road
Jim
I used the NuTeak- Mahogany/Holly product two yrs ago in my 33 Newport that the teak Holly floor had been badly damaged from water. I had to sell shortly after, although I did get to see it this past weekend and it looks fabulous.Here are some pictures. It is time consuming to lay, especially working in a tight area of the cabin.
http://i1320.photobucket.com/albums/...g?t=1351614594
http://i1320.photobucket.com/albums/...g?t=1351614603
Peter
You may post attachments
You may edit your posts
Rubber flooring in the cockpit Kiltmadoc Gear & Maintenance 14 06-01-2012 01:59 PM
Cat 22 - teak flooring? radioguy Catalina 2 09-17-2010 06:24 PM
Replacing Teak Flooring Trescool Gear & Maintenance 1 06-23-2008 05:42 PM
Holly/Sole Flooring Neicy Gear & Maintenance 7 01-19-2006 07:37 PM
Teak Flooring tjgault Gear & Maintenance 1 02-02-2004 06:33 AM
SEO by vBSEO 3.6.1
