Forces acting on mast plate - SailNet Community
 1Likes
post #1 of 26 Old 11-01-2012 Thread Starter
Barquito
Barquito's Avatar
I installed a mast plate this past spring, with the intentions of running some lines back to the cockpit. On my boat the main hatch is off-set to stbd, therefore, all of the lines will be on the port side. Will all of the blocks at the base of my deck steped mast, all pulling in about the same direction... um... pull the base of the mast out? The plate is screwed down throught the mast step into the deck with about 10 1 1/4" screws.
Valiant 32
Barquito is online now
post #2 of 26 Old 11-01-2012
Junior member, rest old
msmith10's Avatar
Re: Forces acting on mast plate
Is this a collar that goes around the mast step or the step itself? Screws or thrubolts?
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 26 Old 11-01-2012 Thread Starter
Barquito
Barquito's Avatar
It is a plate that goes under the step. It is one I got from catalinadirect. I had to drill 10 holes around the big hole in the middle.
Valiant 32
post #4 of 26 Old 11-01-2012
msmith10's Avatar
I doubt if it's a problem. It should be thrubolted for it's own sake, but as long as the mast step is thrubolted it shouldn't disturb the mast step. I'd be concerned about it pulling out, though, if it's just screwed in.
Mark Smith
msmith10 is offline
post #5 of 26 Old 11-02-2012
I would through bolt the plate, with at least washers inside. Stainless steel plates look nicer though.
Above deck :
and inside :
MarkSF is offline
post #6 of 26 Old 11-02-2012
Senior Moment Member
SloopJonB's Avatar
On a 27' you can use fender washers for backing or make backing plates of aluminium as well but, as Mark says, polished S/S looks best - it's also the hardest to make.
Don't worry about the lateral forces on the step - it's a 27 footer - the forces aren't that great.
SloopJonB is online now
post #7 of 26 Old 11-02-2012 Thread Starter
Barquito
Barquito's Avatar
MarkSF - That looks good. Do you have a fiberglass headliner? Was wondering if is is strong enough to put backing plates directly on liner.
Probably proportional to bigger boats. But, so is the hardware. The thing that worries me is that they will all be in the same direction. Although, even if on both port and stbd, they would all be pulling back.
Valiant 32
post #8 of 26 Old 11-02-2012
On my boat the deck is solid, just gelcoated on the inside, there is no liner per se.
Bristol originally used the same backing plate design for the main halyard that came back to the cockpit, so I copied it for the new hardware I've added, for continuity of appearance.
It is possible to work with s/s plate at home with the proper technique. I cut it with a jigsaw with HSS blades (they do go blunt quickly), drilled it with HSS drills, filed it, then sanded it from 60 down to 1000 grit progressively.
When cutting or drilling stainless, the trick is low, low speed, plenty of coolant, plenty of force.
MarkSF is offline
post #9 of 26 Old 11-02-2012
Old as Dirt!
svHyLyte's Avatar
Ah... Isn't it a bit late to think about that?
As a practical matter, screws are good in shear--i.e. loads across the screw--but not so great in tension--loads along the length of the screw. Assuming you mast passes through the base plate rather than bearing upon in, the question then becomes what the screws are screwed into and whether that material will endure the prospective tension loads applied by you lines. The turning blocks through which the lines pass will apply a load to the base plate at an angle that bisects the angle made by the line as it comes down from the mast and turns around the block. If that turning angle is 90, the load applied to the plate will be at a 45 and equal to the load in the line (tension) divided by the cosine of 45. Assuming the plate is sufficiently rigid, the vertical loads will be carried by at least several of the screws you installed. If the plate is flexible, however, and it looks as it it might be, only the screws in the closest proximity to the turning block/line will be loaded (in withdrawal) which is undesirable. If your mast is deck-stepped with the step sitting atop the base plate, then the screws with endure far less withdrawal loading and, in shear, should be okay.
The saving grace to the foregoing (assuming a keel stepped mast) is that, on your boat, the loads on the lines may be sufficiently low that you'll get away with your lash-up. The only loads I can see you having to endure are the jib and main halyards and perhaps a cunningham. A vang lead should go the the mast itself rather than the base plate. Other likely loads, reefing lines etc. would only be applied when other line loads are somewhat reduced.
Hindsight is (almost) always 20/20. It's foresight one needs work on eh?
FWIW...
svHyLyte is offline
post #10 of 26 Old 11-02-2012
SloopJonB's Avatar
Not really - dimensions and forces on boats vary exponentially with the size of boat, not proportionately or even geometrically.
mast deck hinge plate and halyard organizer plate on spirit 23 Southron Spirit North American Yachts 4 03-31-2012 05:59 PM
Mast Step Plate SailingWebGuy Gear & Maintenance 20 12-13-2010 06:34 AM
How big are the holes in your mast step plate? jarcher Gear & Maintenance 3 02-01-2010 08:25 AM
how to mast plate MtHopeBay Gear & Maintenance 2 12-14-2009 09:43 PM
Mast Plate seal weephee General Discussion (sailing related) 1 07-08-2009 07:32 PM
