Holding tank repair/replacement - SailNet Community
post #1 of 3 Old 11-03-2012 Thread Starter
I am attempting to repair/replace the holding tank on my boat. I have been advised about a coating that can be applied to the interior of the tank that will address the problem. KBS Coatings is the manufacturer and they say that it has been a successful resolution to a number of holding tank leaks. Has anyone had any experience with this product? Any comments appreciated, thanks.
Paige, Too is offline
post #2 of 3 Old 11-03-2012
kd3pc's Avatar
Re: Holding tank repair/replacement
any coating that is applied through the holes/vents/inlets of an already used holding tank are of little value. Especially a plastic tank, as few coatings are stout enough to adhere, even to a new plastic tank. Metal tank is already compromised by sewerage, chemicals, rust/oxidation, etc....so that you will be coating the residue at best.
Unless you are dealing with a new tank and can rotate it throughout it's entire possible holding capacity, the coatings are marketing spin.
Your only solution is replacement
kd3pc is online now
post #3 of 3 Old 12-04-2012
Try a Nature's Head or similar. It is the biggest advance to our sport since self steering.
Nature's Head composting toilets
richardb123 is offline
CS27 Holding & Water Tank Replacement cghubbell CS Yachts 9 09-29-2011 07:50 AM
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
Holding Tank Replacement chef2sail Gear & Maintenance 6 01-02-2009 09:00 AM
350 holding tank replacement help please. geop Island Packet 3 06-06-2008 11:47 AM
holding tank replacement pmesmer Gear & Maintenance 11 01-25-2008 08:06 PM
