Toe Rail Replacement with White Oak or ? - Page 4 - SailNet Community
 8Likes
post #31 of 41 Old 12-08-2012
Over Hill Sailing Club
smurphny's Avatar
Re: Toe Rail Replacement with White Oak or ?
I've often wondered why Locust is rarely mentioned for boatbuilding. In post and beam construction it is used for the pegs that hold joints together because of its strength but I don't think I've ever seen it cut and planed into dimensional lumber. If doing a teak replacement for something like a toe rail, I think it might work out really well. There is a LOT of it in the NE, at least down through NY. I once cut down a stand of it on LI to build a house and there is quite a lot here in the Adirondacks. It's puzzling why it usually winds up as firewood. By the way it makes GREAT firewood as well! Maybe it's the twisty nature of it that makes it hard to mill.
smurphny is offline
post #32 of 41 Old 12-08-2012
wolfenzee's Avatar
Location: S/V Waltzing Matilda, Port Ludlow, WA (NW Puget Sound)
Locust is known to check so if you are going to use it on a bend like a toe rail you have to be "very" careful as to where the grain goes and whether or not it wants to check...look at the wood and the grain to see what it wants to do, if it doesn't agree with what you want to do you need to approach it differently. I don't know how much of a bend you have, ideally of course would be to cut out the wood to match the curve, the cap rail on my boat is 3/4" thick and 3" wide.....not the sort of thing you can bend so it was made in sections. What you have can be bent, it might have to be steamed, but with the size and length you might be able to get away with out bending, if you use the right wood.
wolfenzee is offline
post #33 of 41 Old 12-08-2012
smurphny's Avatar
The teak toerails on my boat are still in decent shape. Was just wondering why Locust seems to be ignored as a boat wood. Maybe it because of the grain as you have indicated. I'm going to have to rip out some pieces with my chainsaw, run it through the planer, and try working it to see what kind of qualities it has. Oak, as Brent mentioned, discolors as soon as water gets to it and it is not great at repelling rot. I'm wondering if Locust would not work for gunwales on small wooden boats instead of oak or less durable hardwoods. Waiting for someone to chime in here who has actually tried working with it.
smurphny is offline
post #34 of 41 Old 12-08-2012
wolfenzee's Avatar
When I broke my oak tiller I went over to the mill in the local shipyard and asked the old guy that ran it "What do you have in the way of exotic hardwoods for a tiller?" He responded "Black Locust is a pretty exotic hardwood, come back tomorrow". I came back the next day and he had a slab of Black Locust 18"x4"x12', we took my old tiller and cut out a piece with a grain that lined up and planed it down to 2" thick 7' long ($40). When I finished it off after sailing with it awhile it is now 6' long, rounded at the helm end, chamfered, w/ auto pilot stub, tiller brake and varnished. I have some pretty exotic woods on my boat, but this is one of the prettiest....It doesn't flex the way the oak did and I am alot more confident in it.
post #35 of 41 Old 12-08-2012
72 C&C Corvette
CorvetteGuy's Avatar
I replaced my very thin 40 y/o teak grab rails on the top side with cherry wood, the raw teak I needed to do the job was about $400 bucks. My father cut down a big ole cherry tree and had it milled into boards , I used 1 board cut 2 rails out of it and put it on the topsides, 5 years later it still looks great and I also oil all the other teak on the topside, the cherry holds the oil and look just like the rest of the teak. Good tight grain..
CorvetteGuy is offline
post #36 of 41 Old 12-09-2012
S/V Wyndwitch - Morgan 24
oysterman23's Avatar
I'm with Caleb on this one. If you need top notch runs of teak and don't mind freight try Robert's Plywood in Deer Park Long Island.. Incidentally white oak is what made Old Ironsides hold up to all that cannon shot....and it ages well though its use for railings, rails etc that would be visible was limited to work boats in the age of wood. Locust is damn near immortal I still dig it out from old bungalow footings here on the South Shore...those posts went in about 1865-1900.....they rotted only at the point of air contact!
Epoxy is wonderful stuff, but when used as a sealer exposed to UV has No resistance to UV and must be coated with mulitple coats of clear finish or...one or two of urethane paint. Old growth or True Honduras or Cuban mahogany is bloody gorgeous marine wood glues beautifully shapes well, does not split like Teak can and though it greys has a moderate resistance to rot. Alot of people have it confused with what has been known as Philippine Mahogany or Luan which is really not very attractive has little figure and no comparable longitudinal strength.... When I was a kid the local custom boatbuilders would collect over any Cuban Mahogany they got a hold of....One thing though....quite unlikely your toe rails are uniform in angle and shape from stem to stern and likely need to be fitted and formed as you go...if you are not a carpenter or woodworker it is not a fun job...
oysterman23 is offline
post #37 of 41 Old 12-09-2012
Before making any decisions look at Sapele: Entandrophragma cylindricum.
It looks a lot like mahogany, used for boat building and flooring, has good rot resistance, finishes well and it costs $4.69 a board foot.
Dick
bristol299bob likes this.
Last edited by Flybyknight; 12-09-2012 at 10:02 PM. Reason: add flooring and boat building
Flybyknight is offline
post #38 of 41 Old 12-09-2012
smurphny's Avatar
If the toe rails are anything like they are on my old A35, you are exactly right. They are not anywhere near uniform and have plenty of compound angles to deal with. It would be a chore to replace them.
I used to get my White Oak from Harned's Mill in Hauppauge. I hear they amazingly are still in business. There was also a yard in Bayshore, right off 5th Avenue, with sheds full of White Cedar and other boat woods. I forget the name. Back 40 years ago there were many good sources on LI but nowadays a lot of the traditional species are unavailable, at least in decent sizes. Geez, in Deer Park we used to get Chrysler Crowns, Royals, and Aces from a place called Marzak. He had Chrysler engines and parts from the 40s, all sealed in wax with Chrysler guarantees!
oysterman23 likes this.
smurphny is offline
post #39 of 41 Old 12-10-2012
wolfenzee's Avatar
Dick
Sapele is one of my favorite marine woods, it is easy to work, strong, durable, look super and doesn't have and issues (like checking or ungodly high price). It varnishes up very nicely. I just made some running light boards useing it.Talking to shipbuilders useing it for planking....it's alot easier to bend.
post #40 of 41 Old 12-26-2012
SVTatia, I am a new member and must wait the seven days to send you a direct message. I am in the process of replacing all wood on my Pearson 33 that was damaged in hurricane last year. I am using Cumaru and would like to discuss with you. Could you please contact me? Ref blog for pics by my girlfriend: sailnchck.wordpress.com
Thank you, John
Coastalsailor48 is offline
Rub Rail Replacement ahalfon Gear & Maintenance 17 07-26-2016 11:10 AM
Toe Rail Replacement ambianceack Gear & Maintenance 6 08-07-2013 12:29 PM
rub rail replacement fstuart SailNet FAQ 1 12-01-2011 12:40 PM
Toe Rail Replacement: Teak or Mahogany snook91901 Gear & Maintenance 15 10-31-2011 02:57 AM
Bow Rub Rail Replacement eobpt Gear & Maintenance 2 10-13-2008 06:34 AM
