Toe Rail Replacement with White Oak or ? - Page 5 - SailNet Community
 8Likes
post #41 of 41 Old 12-27-2012
S/V Wyndwitch - Morgan 24
oysterman23's Avatar
Re: Toe Rail Replacement with White Oak or ?
I thought SMurphy might get a charge out of this text I found online re Locust and the name of the place in Bayshore was Kirkup's Lumber....
The following paragraphs were published in the magazine, Scientific American (Volume 2, Issue 16), on January 9, 1847. The first part talks about the strength of black locust wood when used in wheels, and the final sentences talk about its resistance to rot.
The following notes relative to the duration of the locust wood (Robinia pseudo acacia,) have been made by M. Pepin, Jardin du Roi, Paris :
A number of trees were felled that had been planted from 40 to 50 years; but not more than one to five of those wheelwrights [makers of wheels] who came to purchase, appreciated sufficiently the locust, the others preferring elm.
Ultimately the locust was sold to the persons who knew its value, at one third higher price than the elm. The purchasers found that spokes made of the wood in question lasted two sets of felloes [wheel rims], and were likely to answer for a third. Under equal circumstances of wear and tear, spokes made of locust wood were perfectly sound, while those of oak required to be replaced.
M. Pepin further states that the ends of locust gate posts which had been in the soil for upwards of forty years were still not decayed.
This sort of wood employed as feet or supports to chests made of oak, proved sound, although the oak plank in contact with them had been thrice renewed; but oak supports decayed simultaneously with the oak planks composing the chests. Vine props of locust wood are greatly esteemed.
oysterman23 is online now
Rub Rail Replacement ahalfon Gear & Maintenance 17 07-26-2016 11:10 AM
Toe Rail Replacement ambianceack Gear & Maintenance 6 08-07-2013 12:29 PM
rub rail replacement fstuart SailNet FAQ 1 12-01-2011 12:40 PM
Toe Rail Replacement: Teak or Mahogany snook91901 Gear & Maintenance 15 10-31-2011 02:57 AM
Bow Rub Rail Replacement eobpt Gear & Maintenance 2 10-13-2008 06:34 AM
