Jeff H''s advice about not painting wooden spars struck home (re earlier thread about painting wooden mast). I laid a measure along the
jib and mainsail booms and photographed them with fittings in place before removing everything.
Removing the
paint wasn''t too difficult, and with at least a week of cold weather ahead, applying Deks Olje oil #1 seemed the way to go because it isn''t particular like
paint and
varnish to temperature and humidity.
Couple problems I''d appreciate advice about
1. When using heat gun to strip
paint, the putty knife snagged on the wood and lifted long pieces of the grain in several spots. How can that be avoided?
2. After the
paint was sanded off, some very fine cracks in the wood appeared at the fore end of the
jib boom near the gooseneck, and in the middle of the mainsail boom. How to fix? Soak in
epoxy?
By the way, a tip I saw somewhere on SailNet a while back really works. I''d tried before without results, but maybe because I didn''t give it enough time.
Here''s the tip: coat old bronze with catsup. Let it sit for 2-3 days. Scrub it off and you get a dull pink color. Rub with bronze wool and you get a like new shiny bronze surface.
