Making a Rudder - SailNet Community
post #1 of 3 Old 11-04-2012 Thread Starter
Making a Rudder
I have a 15' sailboat with an old rudder that is totally shot. The old rudder was fiberglass over plywood. So I copied the old one as a template onto a piece of 3/4" high quality plywood, cut out the pattern and shaped the wood. Now I am ready to put a layer of fiberglass over the plywood. Once that is done I will need to sand it smooth and apply some sort of protective finish, probably a good marine paint. I am not excited about using GelCoat since it is tricky to work with and to try and get a good result the first time,as well as the fact that it is expensive and I only need a small quantity anyway. Will a marine paint suffice to protect the new rudder from water under light sailing conditions and useage? The boat will be kept on a trailer except when I'm day sailing.
Rxboat is offline
post #2 of 3 Old 11-04-2012
Junior member, rest old
msmith10's Avatar
Re: Making a Rudder
Paint will be just fine. I'd use a 1 part polyurethane since the boat is being dry sailed. Just make sure those edges are well sealed.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 3 Old 11-05-2012
rhr1956's Avatar
Re: Making a Rudder
I'm not sure I would worry about glass cloth...just a few coats of epoxy resin, then a couple coats of paint should do it. You can always spruce it up with a little sanding and paint as needed.
rhr1956 is offline
Tags
complete rebuild , epoxy , marine paint , new rudder , paint or gelcoat
making new rudder for Cal 34 fedor Gear & Maintenance 2 04-01-2012 07:45 AM
ice making JRA1968 SailNet FAQ 8 01-10-2012 08:08 AM
Rudder cap stuck on rudder, how to remove? Capt. Mhack Gear & Maintenance 1 11-30-2011 11:55 AM
Making Passage w/o a Rudder wind_magic Seamanship & Navigation 60 07-16-2010 01:23 PM
Making It along the Way Sue & Larry Cruising Articles 0 01-31-1999 07:00 PM
