Gas Squirting from Carb Top - SailNet Community
post #1 of 4 Old 11-05-2012 Thread Starter
paulopinto's Avatar
Hi all,
My 6hp Tohatsu has always had trouble idling so I cleaned the carb by soaking it for a few hours, sprayed the jets etc and remounted. The idling issue didn't go away but now a new problem came up: GAS SQUIRTS FROM THE TOP OF THE CARB when priming the ball or when the engine runs.
This points me to think there's something wrong with the float or the fuel pump. I didn't disassemble the float when I cleaned the carb since it seemed to be working ok. Today I took out the fuel pump but at first sight I don't see anything wrong either.
Any help is appreciated.
Thanks,
paulopinto is offline
post #2 of 4 Old 11-05-2012
azguy's Avatar
Re: Gas Squirting from Carb Top
I don't know about the gas squirting, but many times trouble idiling can be a vacume leak....Good luck
azguy is offline
post #3 of 4 Old 11-05-2012
Sounds like the float valve is stuck open and you are getting fuel out the float bowl vent.
"Just call me TB"
capttb is offline
post #4 of 4 Old 11-05-2012 Thread Starter
paulopinto's Avatar
Thanks for the input, I'll check the float and valve.
Help with Johnson 4hp carb AdamHowie Outboard 11 02-06-2014 01:58 PM
How much gas in the carb? QuickMick Atomic 4 8 12-28-2010 10:24 AM
carb question for yamaha outboard Incantation Gear & Maintenance 1 11-01-2010 01:43 AM
CRUSING THE CARB IN SUMMER jsgsail Cruising & Liveaboard Forum 4 05-24-2004 03:31 PM
