Patrscoe, I tried to PM you back regarding this thread:
69570-simrad-sd10-autopilot.html
but it wouldn't let me as I don't have enough posts. Similarly, it won't let me post a link to that thread, but a search will get you there.
Here's a summary of what I attempted to send.
I worked up a plan for installing an SD10, and in the end I couldn't personally justify the work that would have required. So I went with an X5 wheelpilot instead. I sold my NSS7 and replaced it with an e7 to have some degree of
autopilot control from the MFD. The NSS has better
autopilot control, but the e7 worked fine last summer. The X5 worked well also. It did throw an alarm once, and when I disengaged it I realized I had a ton of weather helm, so the alarm was due entirely to my ignorance. We threw in a reef and it took us the rest of the way to our destination without issue. Our boat is about 15,500 pounds.
Clearly a below deck
autopilot has other benefits, but I couldn't get into the project given other things I have going on.
Good luck with your project!
