help me with my hull to deck joint!! - SailNet Community
post #1 of 7 Old 11-05-2012 Thread Starter
Its moldy , I cleaned it ,
Edges are thin and sceptical but chainplates are sound structurally decent
I want to insulate or something thinking pink panther stuffed angled in the corner with crown molding??? Any opinions help!
jaymckay is offline
post #2 of 7 Old 11-05-2012
Re: help me with my hull to deck joint!!
On a previous boat all the deck joint hardware was hidden behind a sort of Valance hung from the underside of the deck, blocking the view of that unsightly area but not blocking access.. It seemed to work for us. It was a teak plywood strip screwed into a cleat pieces screwed into the underdeck.
A coat of paint would clean that up too and make it not seem so 'obvious'.. doing both would ease the occasional 'glimpse' you'll get behind the valance. I like Interlux's 'bilgekote' for that kind of work.
Something like this:
Faster is offline
post #3 of 7 Old 11-05-2012
finding41's Avatar
Send a message via Skype™ to finding41
I would get rid of the mold before painting. I like the valance idea!
finding41 is offline
post #4 of 7 Old 11-12-2012 Thread Starter
Faster thanks! I have the pieces you talk about but they are warped and old.. ill save them as templates and just have to do the same thing but with newer teak... except my pieces were completely blocked and screwed in. I had to remove them to see this. and to clean the mold.. ahh the joy of a good ole boat
jaymckay is offline
post #5 of 7 Old 11-12-2012
paulk's Avatar
You do NOT want to put fiberglass insulation (pink panther) up into the space behind your valance or "crown moulding". It will soak up moisture and turn into a mold-generating, rot-spreading wick of horrible proportions. If you have to insulate, use a closed-cell foam of some type (the blue styrofoam, for example) that doesn't absorb moisture and which can be shaped to a close fit. Remember that you may need to get at the hull-deck joint again later - perhaps to track a leak or re-bed a stanchion - so don't glue stuff in there either. Perhaps you can put a screw through the valance every here & there to hold the foam in place. If you don't like the color of the insulation you may be able to paint the side that shows. (Watch out- some paints will dissolve foam!) Looks like you have enough to keep you busy until August or September, anyway. Enjoy!
paulk is offline
post #6 of 7 Old 11-12-2012
paulk's Avatar
P.S. Crown moulding would be an incredible bear to install because of the rolling bevels you'd have to put in on both the top and bottom edges. Nothing in a boat is flush, plumb, or level. Plus, there's not much to attach it to, and you'd need to make it removeable for access to the joint. The valance is the way to go if simple painting doesn't do the trick.
paulk is offline
post #7 of 7 Old 11-13-2012 Thread Starter
Paulk thanks! I reconsidered the panther after realizing exactly that. I like the foam idea along with behind a valance.
My original "crown moulding" was just a thin sheet of teak angled in the corner and screwed in every so often.
jaymckay is offline
Tags
hull to deck
Seeking opinions for deck and hull-deck joint repair gregor1234 Gear & Maintenance 8 04-25-2012 11:10 PM
Sealing the hull and deck joint SSBN506 Gear & Maintenance 3 03-16-2009 07:15 PM
Deck to Hull Joint voice3 Sailboat Design and Construction 9 11-03-2008 05:10 PM
hull deck joint ArgleBargle Sailboat Design and Construction 5 09-28-2008 07:45 PM
Split deck cap and leaking hull/deck joint alaskaboy Gear & Maintenance 2 01-04-2008 09:25 PM
