What is this piece of sailing gear? - SailNet Community
 2Likes
  • 1 Post By smackdaddy
  • 1 Post By Geoff54
post #1 of 10 Old 11-07-2012 Thread Starter
This belongs toa friend and I cannot locate him anymore. The company logo on it is "N M" with a stylized sailboat between the N and M. I looked up the patent number and it has something to do with winches.
Frogwatch is offline
post #2 of 10 Old 11-07-2012
Re: What is this piece of sailing gear?
Believe it's an old style jam cleat/clutch. I have some snatch blocks w/ the same logo; came w/ my boat.
CS 36M DIANTHUS
sailordave is offline
post #3 of 10 Old 11-07-2012
Looks like a jam cleat with a handle to help release the line being held.
bogdog is offline
post #4 of 10 Old 11-07-2012
HANUMAN
RobGallagher's Avatar
I believe it's a cleat.
RobGallagher is offline
post #5 of 10 Old 11-07-2012
chucklesR's Avatar
Jam cleat, where the roundish knob on the handle goes into the winch, effectively holding the bitter end right at the winch (but not like a self tailer as it would not self tension).
chucklesR is offline
post #6 of 10 Old 11-07-2012
It's a two-speed Newbie-Whacker.
chef2sail likes this.
smackdaddy is offline
post #7 of 10 Old 11-07-2012
Geoff54's Avatar
Don't be ridiculous! That's only the single speed version.
smackdaddy likes this.
Geoff54 is offline
post #8 of 10 Old 11-07-2012
Old as Dirt!
svHyLyte's Avatar
It is a cam tightener from the '50's-60's. It was part of a fitting that included a bullseye through which a line was led, then through a cam cleat, and then a post, all on a backing plate typically fitted to a boom or mast on a small boat. One would slide the cam tightener over the post and lead the line over the wheel and under the cam on the handle. With that, one could "tail" the line with one hand and tighten it with the other and "crank" as needed. They were commonly used to tighten outhauls and reefing lines on booms that weren't large enough to take a winch but that needed a mechanical advantage to set the lines up properly or on small boat masts. One handle was all that was needed for several fittings. They actually worked pretty well.
FWIW...
svHyLyte is offline
post #9 of 10 Old 11-07-2012
Life is a wild ride!
Dean101's Avatar
I like Smack's "newbie whacker" idea answer better even though everybody else seemed to concur on the jam cleat thing!
Dean101 is offline
post #10 of 10 Old 11-07-2012 Thread Starter
Am trying to figure out if something like this could be used as a sort of "self tailing" winch handle although I actually dont understand how self tailing works and never felt I needed it.
Your ONE piece of wisdom... MedSailor General Discussion (sailing related) 150 06-05-2012 03:32 AM
Hunter 28 really a piece of ****? TheSeaPenguin Boat Review and Purchase Forum 16 10-03-2009 12:03 AM
Gear confessional: what was the last piece of gear you bought merlin2375 Gear & Maintenance 60 07-05-2008 10:45 AM
Two piece mast? L124C Sailboat Design and Construction 3 10-20-2007 10:05 PM
