Stuffing box & grease fittings - Page 3 - SailNet Community
post #21 of 23 Old 11-12-2012 Thread Starter
Re: Stuffing box & grease fittings
Copa,
I covet your setup. I have to use a standard grease gun, standing on my head of course. It is interesting that the grease in your system exits forward of the compression ring (I am glad you didn't have a chance to clean it up before you took the pictures). Makes me think the forward (second) grease fitting on my setup is redundant and maybe not necessary. Can you give me a little more information on your rationale for using a standard grease instead of a waterproof grease? Is this consistent to what you have seen others use with similar setups? This sounds counterintuitive, but the more I think about it the more sense it makes. Very interesting.
Kenn43 is offline
post #22 of 23 Old 11-12-2012
Kenn, I just continued using the same grease that the previous owner had been using. Since he was the one who installed the thing (and he is a very experienced cruiser) I just followed his lead. All grease is "waterproof" in the sense it doesn't dissolve in water. I think that white "nautical" grease will eventually cake up inside the stuffing box. Wherever I've used the stuff it eventually ends up as a crusty white paste. Since the grease is really just to lubricate the shaft and stuffing (and fill any voids where water could accumulate) I don't see why it has to be waterproof nautical grease.
My sense is that if you install a grease gun like mine, it will deliver the grease under pressure, eventually pushing it through the flax rings and out the shaft (like in the photo). In this case, I can't see the use for the other grease nipple. My grease gun is really simple- it's a cylinder with a threaded cap with an 0-ringed "plunger" inside. You keep turning the "T" on top, forcing the grease down through the hose and into the stuffing box. I'm sure the grease gun is available and not uncommon. It's made of bronze which might mean it is a "marine" thingy. Start at a truck/tractor shop and see if they have a similar one. I think the grease should be delivered under pressure so it penetrates the stuffing box.
Vindö 50
copacabana is offline
post #23 of 23 Old 11-13-2012
Originally Posted by Omatako View Post
I am contemplating making a dripless seal for my propshaft. Yes I know you can buy them but they're expensive and besides it's not only about saving money, it's about the sense of satisfaction.
A Marelon tube with three double-lipped oil seals as used in vehicle wheel bearings but the type that is fully rubber encased to prevent the shell from rusting. Between each seal a collar with a groove running around to distribute grease to the bleed-through hole.
The first two seals face the incoming water, the third at the other end of the tube faces the other way to contain the grease.
Then a zerk (? - I call them grease nipples) between the seals that allow the whole assembly to be pumped full of waterproof grease. From outside it would look like this:
It will take up less space on the shaft than the stuffing box I have now which I actually consider to be pre-historic and I reckon it will work really well.
Any reason why this would not work? The total cost excluding my labor (which when invoiced to me is really inexpensive ) would be about $40.
Your drawing looks just like the rotating center column of a beverage filling machine from a bottling plant. This type of design has been in use for a very long time and it works great.
A couple of things: Because you want to eliminate water intrusion, the grease has to have some miniscule amount of flow (leeching is more appropriate than flow) past the rubber seals to lubricate them. The grease must move into the water side and not the opposite as the water will ruin the grease and bearings over time. It looks like you will accomplish this by basically packing the entire thing with grease. That will work fine, but make sure with that much grease that you allow for grease changeout. (weep holes) You will get some water in the grease. It's going to happen. I'm sure you are planning for it as evidenced by your seal arrangement.
The RPM of the shaft is probably the driving (pun intended) factor of how long your seals will last. Engine crank seals / transmission seals sound like a good place to start since that's what they effectively do.
I see you plan to add zirks for the bearings. I also suggest putting the zirk on the face of each seal. pump grease around the curcumferenace of the seal. Grease will overflow the seal and will fill the cavity between the seals. But you need a channel to contain the seal anyway, and that channel needs to be filled with grease. (wet the seal on all four sides, since you're talking square seals). My suggestion is to add small weep holes on the opposite side of your seal journals. (In other words, the zirk is at 12 o'clock on the seal journal, and the weep hole is at 6 o'clock. The grease will follow the journal around on both sides and push out at 6 o'clock.) You need to see fresh grease oozing out to know you are getting grease all the way around the seal. Also, if there are no weep holes, there is no way for the journal to excrete the soap (used grease leftovers) and accept new grease. If that happens the old soap will just dry up and the seal won't be lubricated- then the shaft will eat the seal up right away.
Every grease channel needs a weep hole. So, for each zirk, factor in a weep hole on the opposite side. With a liquid like oil or transmission fluid this isn't necessary because you always have flow. With grease you need weep holes.
Do you have a grease in mind? I would suggest Lubriplate NLGI 2 or similar.
Just my .02 I love your design.
ShoalFinder is offline
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 04:48 PM
Grease fitting on stuffing box? downeast450 Gear & Maintenance 3 04-17-2010 01:07 PM
Wax And Grease nelsonsmoody Gear & Maintenance 4 02-27-2010 05:00 PM
Stuffing Box Grease quinlanmw Cheoy Lee 0 08-27-2007 01:18 PM
Stuffing Box Quickie - Grease clayjay Gear & Maintenance 1 08-10-2007 09:18 AM
