Stuffing box & grease fittings - SailNet Community
post #1 of 23 Old 11-08-2012 Thread Starter
I have a question about the stuffing box on my boat. I have attached a picture to show the arrangement. The stuffing box has two grease fittings, one on the compression ring and one on the end of the male fitting. I have been able to find a couple examples of stuffing boxes with the fitting on the compression ring, but have not found any examples with the other grease fitting.
Has anyone else run across a setup like mine? Should grease be used in both fittings? Why is there a fitting on the male side? Could grease in the fitting on the male side interfere with water flowing through the stuffing box?
Any other information, thoughts or ideas will be appreciated.
Kenn43 is offline
post #2 of 23 Old 11-08-2012
Maine Sail's Avatar
Re: Stuffing box & grease fittings
Looks like a DIY jury rig.. That box style did not come with zerks and they can and do create the potential for corrosion as they are not bronze. The aft zerk will prevent cooling water from getting to the box once the log is filled with grease.....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 23 Old 11-08-2012
Learning the HARD way...
eherlihy's Avatar
That's the damndest thing that I've seen in a long time...
I believe that it is time for a new stuffing box. Too bad, because it looks like a relatively new one.
eherlihy is offline
post #4 of 23 Old 11-08-2012 Thread Starter
It looks new to me too. I just don't understand why anyone would install the grease fittings. Is it a good idea or a bad idea? I don't know.
Kenn43 is offline
post #5 of 23 Old 11-08-2012
Gene T's Avatar
Drinking and boating doesn't mix.
Gene
Currently in Long Beach, CA
Gene T is offline
post #6 of 23 Old 11-08-2012
Mine has a grease fitting as well and it seems to replace the water for lubrication and cooling. There is a grease gun mounted on the bulkhead over the engine with a hose to the stuffing box. I give the screw cap a turn every 20 hours or so. I was also skeptical about the grease fitting until I saw it used extensively in fishing boats here. I can say that after a long run on the engine the stuffing box is still cool to touch. The other benefit is that I don't have a drip at the gland.
Vindö 50
copacabana is offline
post #7 of 23 Old 11-08-2012 Thread Starter
Copa,
Does your stuffing box have two fittings like mine? If not, which one do you have?
Kenn43 is offline
post #8 of 23 Old 11-08-2012
No, just one fitting (one grease entry point). I'll take a picture of it this weekend when I go to the boat.
Vindö 50
post #9 of 23 Old 11-09-2012 Thread Starter
Gene
I hear you on the drinking and boating, but I am still holding out hope that someone will show up with some helpful information.
Kenn43 is offline
post #10 of 23 Old 11-09-2012
Omatako's Avatar
I am contemplating making a dripless seal for my propshaft. Yes I know you can buy them but they're expensive and besides it's not only about saving money, it's about the sense of satisfaction.
A Marelon tube with three double-lipped oil seals as used in vehicle wheel bearings but the type that is fully rubber encased to prevent the shell from rusting. Between each seal a collar with a groove running around to distribute grease to the bleed-through hole.
The first two seals face the incoming water, the third at the other end of the tube faces the other way to contain the grease.
Then a zerk (? - I call them grease nipples) between the seals that allow the whole assembly to be pumped full of waterproof grease. From outside it would look like this:
It will take up less space on the shaft than the stuffing box I have now which I actually consider to be pre-historic and I reckon it will work really well.
Any reason why this would not work? The total cost excluding my labor (which when invoiced to me is really inexpensive ) would be about $40.
Arthur C. Clarke
Omatako is offline
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 04:48 PM
Grease fitting on stuffing box? downeast450 Gear & Maintenance 3 04-17-2010 01:07 PM
Wax And Grease nelsonsmoody Gear & Maintenance 4 02-27-2010 05:00 PM
Stuffing Box Grease quinlanmw Cheoy Lee 0 08-27-2007 01:18 PM
Stuffing Box Quickie - Grease clayjay Gear & Maintenance 1 08-10-2007 09:18 AM
