-   -   fuel tank leak (http://www.sailnet.com/forums/gear-maintenance/9394-fuel-tank-leak.html)
gart 03-23-2004 09:29 AM
fuel tank leak
I have an apparent fuel leak at the sending unit of my fuel tank. If I rebedd the unit should I use a rubber gasket like is now in use ,cork? Gasket sealer? What? the tank is poly if that makes a diff. all input would be appreciated.
steve/B361/ secret"O"life
JosephDive 03-23-2004 12:04 PM
fuel tank leak
From my experience with US naval vessels I would have to reccomend looking for a Garloc gasket. They make gasket/sealing material for nearly every application imaginable. Working with some of their thicker "cut to size" materials could be a pain if you don''t have the appropriate equipment (or access to it) but the results are always favorable. A simple web search should give you atleast a handful of places to order garloc gasket material from as well as what type would fit your purpose.
VR,
Joseph
