Porta-to plumbed?? - SailNet Community
post #1 of 8 Old 11-09-2012 Thread Starter
deltaten's Avatar
Send a message via Yahoo to deltaten
Porta-to plumbed??
Currently looking at/into an Islander 26 equipped with a porta-pottie. The area fwd of the bulkhead shows what looks to be enuff room for a marine toilet....approx. 2'X2'??. Lotsa room aft of the head to route lines and install a tank.
Recommendations on mfgrs? Probably wanna go manual pump vs powered, due to power considerations.
Yea? Nay? Fuggedabowdit?
deltaten is offline
post #2 of 8 Old 11-09-2012
chucklesR's Avatar
Re: Porta-to plumbed??
value depends on how you intend to use the boat, and where (will you be able to get pump outs etc..).
chucklesR is offline
post #3 of 8 Old 11-09-2012
chef2sail's Avatar
value depends on how you intend to use the boat, and where (will you be able to get pump outs etc..). ChucklesR
Make sure you use good sanitation hose as thats where the smell mostly comes in. Trident 101 one of the better ones. We used it when we redid our system.
Also please read up on this as there are many little pitfalls on nistallation which can save you aggrevation down the road such as over/ under waterline issues, vents, and air loops. If you can find articles written by Peggy Hall she is an expert many of us quote or refer to. I find the particvular toliet you use the least of the issues. My philosphy has been to bu the cheapest simplest ones and do the normal maintainenece until the repair costs 1/2 the toliet and then jusrt replace the whole unit. Even these cheap ones will last 8-10 years.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #4 of 8 Old 11-09-2012
I took the marine head outta my 28' S2 and replaced it with a porta-potti. My problems dropped by 90%. I'd spent more time working on that damned marine head than all other systems put together. Now, I hear it is even worse with the law saying you need locking Y valves and such. I gave my holding tank to one friend and the toilet to another and both think I did them sort of huge favor. It was the highest rated toilet but now I have almost no problems.
Frogwatch is offline
post #5 of 8 Old 11-09-2012
tommays's Avatar
Sealand traveler porcelain whole deal 450
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #6 of 8 Old 11-09-2012
Siamese's Avatar
I took the factory toilet out of my 2007 Catalina 309 and replaced it with a porta-potti. For the way I use my boat, I find it far superior to the holding tank system. And I can never have a toilet repair that costs more than a porta-potti. Of course the Porta has performed flawlessly and without odor for five years so far.
Siamese is offline
post #7 of 8 Old 11-09-2012
I put in a rebuilt willcox crittenden skipper head that I got at a boat swap meet. Probably the cadillac of hand pumped heads. As space was limited for a holding tank I installed a Raritan type 1 MSD. We don't have no discharge zones here and the type 1 meets specs. One thing about the Skipper head. It sits higher than its predecessor and I needed to buildt a drop down foot rest
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
post #8 of 8 Old 11-10-2012 Thread Starter
deltaten's Avatar
Thanks for the replies, fellas. Looks like the plumbed-in unit will be a future project. Head, hoses and holding tank; plus fittings and figgerin' where/how it all goes comes to some serious time and bux. Guess I'll have ta live with the porta or the 100 yd dash to the facilities on shore.
deltaten is offline
Catalina 25 the head is plumbed wrong? davidpm Gear & Maintenance 4 07-03-2011 03:18 PM
Urinal plumbed directly overboard ? PopeyeGordon Gear & Maintenance 80 05-27-2011 12:56 AM
Porta Bote lancelot9898 Gear & Maintenance 8 03-03-2009 02:42 AM
Hot water heater plumbed to genset & engine? jonlgauthier Gear & Maintenance 2 07-09-2007 02:01 PM
porta potties? jbarros Gear & Maintenance 6 01-02-2003 06:41 AM
