There She (Fiberglass/ Stern Cleat Torn Out) Blows ! - Page 2 - SailNet Community
post #11 of 12 Old 11-09-2012
pdqaltair's Avatar
Re: There She (Fiberglass/ Stern Cleat Torn Out) Blows !
Great time to look at winches. The PO of my boat added a new winch, but the mounting was hidden above the liner. In a good breeze I tore the sucker out, and just missed losing it. No backing plate under a cored deck. It is a very solid boat, but the builder had not planed on a winch at that location, and the PO didn't even use washers. The nuts crushed the core and started to pull through. It has a big FRP plate now.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #12 of 12 Old 11-09-2012
Cruiser2B's Avatar
Ouch, I used 1/4 aluminum plate and mounted with thickened epoxy to contour of the used side of the deck. I am not sure if this was the correct methos or not but it sure make me feel better. I also added a large stainless mooring bit/bollard to the main deck up at the bow, this has a 2'X2' backing plate. If this breaks loose I am pretty sure the rest of the boat would be junk.
with that said I would repair the area and put the cleat back with a substantial backing plate(large surface area), not wood. And add a bollard if you have room for it for your mooring lines.
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
Blows! dvuyxx Chesapeake / Central US east coast 10 09-12-2010 04:52 PM
Torn between two boats justified Boat Review and Purchase Forum 23 05-15-2009 09:39 AM
Torn sacrificial cover, help me get it down. SDietz Gear & Maintenance 6 11-18-2008 06:17 PM
Changing a V-Cleat to a C-Cleat? funjohnson Sailboat Design and Construction 11 08-21-2008 10:14 AM
Batten pocket torn mwrohde Gear & Maintenance 9 06-29-2007 01:23 PM
