Like Tree1Likes
  #31
Old 11-13-2012
paulk's Avatar
paulk is on a distinguished road
Re: Breasting my fin keel? Help please.
One thing comes to mind after re-reading this thread and looking at the I 28's keel profile. You might want the supports to be a touch heftier than 2x4's, just in case. )(4x4?) Adding a chock or a notch to the upper end of the support so that it fits in a specific spot on the hull might be a good idea too - you don't want the thing slipping too much out of place, once you get it in. The engine & tankage weight aft would make me want a strut back there too, if only to protect the rudder.
  #32
Old 11-14-2012
downeast450's Avatar
Tundra Down
downeast450 is on a distinguished road
Paul,
I agree with your concern about the structural contribution of 2x4s. There was a day that a clear 1/4 sawn 2x4 had some "juice". Those days are long gone. I have a set of pump jack supports I built of carefully selected 2x4s back in the 80s when live edges were not standard on dimensional lumber. I could use them or 4x4s as you suggest. A couple of lengths of 2" sch 40 aluminum pipe would be my druthers with a purchases for the toe rail.
Thank you for your considerate observation. Hoping you dodged the Sandy bullet.
Down
  #33
Old 11-16-2012
Shortman is on a distinguished road
Run up Somes Sound to Jock William's yard. Better rates, good folks. Talk to Jaime.
  #34
Old 11-17-2012
Tundra Down
Shortman,
Thanks. I share your appreciation of Jock William's yard. They are good folks. Having them haul me for a quick fix would certainly work.
There are several options near me that are good options if I need to engage a yard. I am thinking through the complexity or simplicity of just drying out for a tide to check something or clean the hull. If my plan works out, I will have a simple solution 100 yards from my mooring that involves only me, the boat and the moon.
Down
  #35
Old 01-10-2013
K0RINA's Avatar
K0RINA is on a distinguished road
How about Careening a fin keeled boat - halyard down to a pulley on a beach side tree and then haul on a winch to pull the boat over - a dry land broach...to scrape the weed off the bottom.
David Lord Warr
  #36
Old 01-10-2013
K0RINA's Avatar
Thumbs up Re: Breasting my fin keel? Help please.
Originally Posted by downeast450 View Post
Capt
"It's the filling tide that is really annoying." Yup! There must be limits to the hull shape that can stand careening. I am guessing the I-28 is well outside them. I wonder what they are? I have wondered if, in an emergency, I could careen on top of my Avon and with its added buoyancy, keep ahead of the incoming water as I lifted on the tide. Bob Perry might have an opinion. It is his creation.
I can repair the fiberglass.
Down
Now THAT is a GOOD idea
David Lord Warr
You may post attachments
You may edit your posts
Questions about barrier coat on steel keel, and sealing keel joint EricinToronto Gear & Maintenance 1 04-21-2012 09:43 PM
Seafarer 24 swing keel, keel pivot? Sailing qualities? skygazer Boat Review and Purchase Forum 29 03-22-2012 07:45 AM
Full Keel vs. Wing Keel small boats Kyhillbilly General Discussion (sailing related) 4 07-26-2011 11:51 AM
Rusty spots on keel and hull keel joint Stephane99 Gear & Maintenance 1 04-07-2009 07:39 PM
Swing Keel or Fixed Keel for Caribbean Sailing SailorJim123 Boat Review and Purchase Forum 1 02-04-2009 10:15 AM
SEO by vBSEO 3.6.1
