Adler Barbour Cold Machine troubleshooting - Page 3 - SailNet Community
 8Likes
post #21 of 28 Old 11-20-2012
SchockT's Avatar
Re: Adler Barbour Cold Machine troubleshooting
Might have a hard time fitting that down in the lazarette!
msmith10 likes this.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #22 of 28 Old 11-22-2012
chef2sail's Avatar
This would not be a good time to start the discussion on inertia, pendulum, or wave action reciprocating compressors? DeniseO30
Sounda like discussion over my head.
deniseO30 likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #23 of 28 Old 07-14-2015
My Adler /Barbour freezer system I believe has a leak as I am losing the 134a . The problem is we believe
the leak is in an inaccessible area. Is there a technique for fixing the leak? The technician is not very
familiar with the boat system.
Mark is offline
post #24 of 28 Old 07-15-2015
SchockT's Avatar
Wow! Talk about dredging up old threads!
There is a product out there that some guys use called "Easy Seal". Some guys swear by it. I prefer to actually find and repair the leak, but I have used it a couple of times in situations where conventional methods were not practical, and the alternative is replacing the unit. In both cases the leak was sealed and the units worked long after.
Easy Seal
Hull#101
SchockT is offline
post #25 of 28 Old 07-16-2015
aeventyr60's Avatar
You probably have a leak in the line due to chafing on a hard surface, or some salt water has corroded through the thin wall aluminum line. I've brazed small holes, but is only a temporary fix. A new evaporator unit will be cheaper then a refrigerator techs time. Also check the connection between compressor and evaprator fittings..they do come loose...
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #26 of 28 Old 09-19-2015
I've been running R134 in my AdlerBarbour unit for years. It came with R12 and I was told I could not use R134 without changing the
evaporator nozzle or some such bull. I mearly bought a few cans of R134 and gave it a try and it works great. I think too many people shoot from the hip on too many subjects. If you are already looking at a big bill, give it a try, what can you loose?
Don Fleischer is offline
post #27 of 28 Old 09-20-2015
One of None
deniseO30's Avatar
Did you change the oil? you may have lucked out with a newer unit that has compatible oil It would have failed by now.
A few cans? they only hold about 5 oz!
http://docs.lib.purdue.edu/cgi/viewc...&context=iracc
My last project!
deniseO30 is offline
post #28 of 28 Old 09-20-2015
Stu Jackson's Avatar
To the OP:
You said hissing sound.
That is NORMAL. When the unit starts up the refrigerant is being fed through the small lines in the evaporator.
To learn more, go here and ask:
Kollmann Marine
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
Adler Barbour Super Cold Machine bob77903 Gear & Maintenance 1 04-13-2010 01:44 PM
Adler Barbour super cold machine MtnMike Gear & Maintenance 1 01-24-2010 04:57 PM
Adler Barbour Cold Machine jvarner222 Gear & Maintenance 4 08-11-2009 08:33 AM
Adler Barbour Troubleshooting (LED Flash) FortAwesomeIII Gear & Maintenance 16 06-02-2008 11:44 PM
Adler-Barbour Cold Machine CharlesG General Discussion (sailing related) 6 03-10-2006 06:13 AM
