Racor Diesel fuel filter 500MA2 - Page 2 - SailNet Community
 2Likes
post #11 of 34 Old 11-14-2012 Thread Starter
Re: Racor Diesel fuel filter 500MA2
I guess you could use one filter at time and have 100hrs of operation of the engine sounds good
colinflteng is offline
post #12 of 34 Old 11-17-2012 Thread Starter
Could you use your 1/4" hose to connect to the 75500 MAC2 fittings are 3/4"
post #13 of 34 Old 12-14-2012 Thread Starter
Racor 500MA-2 Filter from West Marine asking $244. Can in store On line American price $229. ?
post #14 of 34 Old 12-14-2012
BarryL's Avatar
Hi,
I must have missed this, but what is wrong with the R24S filter? Why doesn't it meet ABYC?
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #15 of 34 Old 12-14-2012
Maine Sail's Avatar
Originally Posted by colinflteng View Post
Has any one using Racor 500MA2 Fuel filter I am planning to replace my Racor R24S Spin on filter that does not met ABYA standards I need to change fittings from 2/4 to 1/4"
If you replace the clear plastic bowl with Racor's optional metal bowl I believe it will meet the standards....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #16 of 34 Old 12-14-2012 Thread Starter
I agree with metal bowl if you can get it, but then you loose the ability to see if any water is in the bowl
post #17 of 34 Old 01-12-2013 Thread Starter
I glad that I measure space for filter I will not have room for the 500MA2 Filter so back to drawing board looking at RACOR 230 RM2 now metal bowel meets specs
post #18 of 34 Old 01-12-2013
Señor Member
PorFin's Avatar
Not quite correct.
The metal heat shield is an addition to, and does not replace, the see-through plastic bowl. You can still see the bottom of the unit to know if you've got water or nasties down there.
Bummer that you don't have room for the 500 -- they're great filters.
________
'85 BYB Vagabond 39
PorFin is offline
post #19 of 34 Old 01-12-2013 Thread Starter
I wish I had more room not ideal to use medal bowl I make sure to change filter on time
post #20 of 34 Old 02-12-2013 Thread Starter
Angry Re: Racor Diesel fuel filter 500MA2
Be aware when you buy a Racor 230 MA2 filter body had to get two units sent to me with filter installed on filter unit filters did not were not installed properly with no fuel on o rings we were unable to remove filter so I recommend people to check that filter can be removed
Racor fuel filter identification.... Rockter Diesel 6 05-01-2012 03:26 PM
Racor Fuel Filter dbruce85 Diesel 2 02-08-2012 07:44 PM
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel 4 06-07-2010 10:01 AM
Racor fuel filter filter guage Grumpymx Gear & Maintenance 5 08-26-2008 09:10 PM
Racor Fuel Filter aphil138 Gear & Maintenance 2 03-15-2004 03:20 PM
