Racor Diesel fuel filter 500MA2 - Page 3 - SailNet Community
 2Likes
post #21 of 34 Old 02-13-2013
Puget Sound Pounder
kellysails's Avatar
Re: Racor Diesel fuel filter 500MA2
I would prefer the metal bowl version, only slightly more expensive than the non-metal bowl version at defender. The current sale price is really good. This filter set is on my xmas wishlist.
Racor Dual Filter, Turbine 500 Series Fuel Filter / Water Separator
This is my current Racor. The dual would be a drop in replacement for me. Now if I can only convince my wife how wonderful it is. Tried to at the last boat show but was not convincing enough
kellysails is offline
post #22 of 34 Old 02-13-2013
Maine Member
BELLATRIX1965's Avatar
That fuel filter looks like it is mounted inside the accommodation cabin (either that, or the fanciest engine room I've ever seen!) - don't think that is an approved installation???
MaineSail would know better.
BELLATRIX1965 is offline
post #23 of 34 Old 02-13-2013
Puget Sound Pounder
kellysails's Avatar
It is not an accommodation room. It is a storage/tool room. Floor space is 2ft by 2ft. I had a VSC two weeks ago by the Power Squadron and they said it was fine.
Port side, aft of the galley area
post #24 of 34 Old 03-26-2013
Fresh water refugee
katsailor's Avatar
what size filter do you use?
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
post #25 of 34 Old 03-26-2013 Thread Starter
I use 2 Micon
colinflteng is offline
post #26 of 34 Old 03-26-2013
Puget Sound Pounder
kellysails's Avatar
My primary is 10 Micron (racor) and the secondary is 2 micron
post #27 of 34 Old 03-26-2013 Thread Starter
Mine reverse first in line 2 Micron then 10 Micron
post #28 of 34 Old 03-26-2013
Fresh water refugee
katsailor's Avatar
why is the finer filter before the coarser filter?
post #29 of 34 Old 03-27-2013
Maine Sail's Avatar
2 micron filters should really not be used for a primary filter. They will clog faster, require more work from the lift pump and is really filtering well beyond where any manufacturers engine needs to be. People just automatically assume 2 micron is better and in many cases it simply shortens the life of a lift pump and clogs when you least want it to.
Racor specifically suggests 2 micron filters to be use as a "final" filter not a primary or even a secondary. Course if you have a clean tank and dedicated on-board polishing system them a 2 mic primary may be okay. In most instances a 2 mic can be fine as a "secondary filter" too.
We have a new tank and a dedicated purpose designed high capacity, high flow on-board polishing system that polishes the fuel to 2 micron and turns the tank over multiple times per hour. Despite spotless fuel and a spotless tank our primary engine filter is still a 10 micron so as not to over work our electric lift pump.
Racor does not even really call the 10 micron a "primary" filter. They refer to the filters as:
30 Micron = Primary Filtration
10 Micron = Secondary Filtration
2 Micron = Final Filtration
MedSailor likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #30 of 34 Old 03-27-2013
Fresh water refugee
katsailor's Avatar
Thanks a lot Maine Sail,
I am installing a new motor and working out the electrical and plumbing logistics of what I need, the 2 micron filter seemed like it would be prone to clogging and putting a 10 micron after a 2 just didn't make any sense.
Are the cheaper spin off Racor fuel filters any good? I heard they have problems out of the box because they won't unscrew and I don't think they meet AYBE? specifications.
Now I need to add 'Clean fuel tank and install inspection cover' to my do list.
Racor fuel filter identification.... Rockter Diesel 6 05-01-2012 02:26 PM
Racor Fuel Filter dbruce85 Diesel 2 02-08-2012 06:44 PM
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel 4 06-07-2010 09:01 AM
Racor fuel filter filter guage Grumpymx Gear & Maintenance 5 08-26-2008 08:10 PM
Racor Fuel Filter aphil138 Gear & Maintenance 2 03-15-2004 02:20 PM
