Racor Diesel fuel filter 500MA2
Has any one using Racor 500MA2 Fuel filter I am planning to replace my Racor R24S Spin on filter that does not met ABYA standards I need to change fittings from 2/4 to 1/4"
Re: Racor Diesel fuel filter 500MA2
Yes, they are very common on many diesel boats. Almost ubiquitous even.
I use this racor on my Cal-40 with a Kabota engine and never had one problem. The filters are easy to find all over the world.
Thank you West Marine sells for $229
Cheers Colin |
I opted for a dual system so that I could easily switch over while keeping the engine running.
http://www.sv-zanshin.com/images/sma...-11-racor1.jpg http://www.sv-zanshin.com/images/sma...-11-racor2.jpg http://www.sv-zanshin.com/images/sma...-11-racor3.jpg |
The dual Racor was the prefab system, I would have built it myself at a lower cost, but I liked the vacuum gauge and lever layout and knew I couldn't have done it as nicely. The unit ships complete as shown in the pictures except for the backing StarBoard used for mounting in the engine room.
Here's the link to the Defender page: http://www.defender.com/product.jsp?...530&id=1716464 I believe I paid around that price as well and sourced it locally in Annapolis, MD. |
That looks like good set up link is for unit with not steal bowl Model 75500MAX2
West Marine has Racor 75500MAC2 Racor filter for 830.00 Defender price better at $630 ?
I have a dual system. I can run fuel through one filter, both filters, the other filter, or none. The boat actually had it plumbed for 2 tanks and one filter but we have one bad tanke because the previous owner filled a steel tank with water SO THAT IT WOULDN'T RUST!
I didn't have the money for another tank but I scored a second Racor 500 for $20.00 so I re-connected the hoses from the one tank to the 2 filters. It sure is nice to be able to clean one filter without having to shut her down and this way I don't need to bleed the system. |
| All times are GMT -4. The time now is 05:02 AM. |
SEO by vBSEO 3.6.1
