Hang Interior Cushions - SailNet Community
 1Likes
  • 1 Post By Skipper Jer
post #1 of 9 Old 11-12-2012 Thread Starter
I have an Oday 34 and in various places backrest cushions are mounted on plywood and then screwed into place from behind.
Does anyone have a good idea on how I could mount a track instead? I want to be able to remove them easily but I do see value in them not moving around too much.
Links or pictures would really be helpful
MeGeek is offline
post #2 of 9 Old 11-12-2012
Skipper Jer's Avatar
Re: Hang Interior Cushions
velcro?
SloopJonB likes this.
Skipper Jer is online now
post #3 of 9 Old 11-12-2012
Ditto velcro. Works well on mine to keep them in place.
Harry
S/V GRACE
Cranes Creek, VA
ccher is offline
post #4 of 9 Old 11-12-2012
Remember you're a womble
PaulinVictoria's Avatar
I fitted a couple of brass hinges to the back of mine, when I want to take them off for the season I just knock out the pins and off they drop. I wanted to be able to lift them up to make more room to sleep but that didn't quite work out
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #5 of 9 Old 11-12-2012
asdf38's Avatar
This is actually a good idea. I had to remove my cushions by unscrewing them from behind from within my little cabinet things. Luckily I had one of those compact right angle screwdriver ratchets otherwise I couldn't have done it.
Here is a good place to get various forms of Velcro
McMaster-Carr
Also consider 3M dual lock. It's the same as Velcro but I think it's stronger and more durable.
asdf38 is offline
post #6 of 9 Old 11-12-2012
Rogue Musician
TheTardis's Avatar
I have a question for you, I have an o25 and want to take the back rests off. How did you get behind there? What tool fits?! Thanks
Brass Belle
'78 Pearson 30, #1099
TheTardis is offline
post #7 of 9 Old 11-12-2012
Another possibility (though I do think velcro would be most practical) might be to attach some luff tape type material to the cushions and mount appropriate tracks for them to slide into.
Not exactly what I had in mind, but perhaps close enough to get the idea:
http://www.simplexstripdoors.com/sdmounting.htm
Talk to your sailmaker about the hardware that might work.
Faster is online now
post #8 of 9 Old 11-12-2012
sarafinadh's Avatar
We have a Ranger, made by the same yard.
The cushions are similar in style but the connection is different. There are brackets at each end of the back rests, and the boards the cushions are on have enough wood exposed at the ends to slid into the brackets. The brackets are made of wood. Think closet rods in the closet only the rod is a board and the bracket is a deep u shape and mounted from the back.
Maybe you could retrofit a mounting system like this?
sara
ain't what ya do, it's the way that ya do it...
sarafinadh is offline
post #9 of 9 Old 11-13-2012
Senior Moment Member
SloopJonB's Avatar
Double ditto to Velcro. Why have them bolted or hinged or screwed in place? I can't see any benefit and several downsides.
SloopJonB is online now
Sewng New Interior Cushions - Help malyea General Discussion (sailing related) 40 01-24-2012 10:23 AM
Need advice on new interior cushions/bedding!! DovaRossi Cruising & Liveaboard Forum 3 01-15-2012 11:34 AM
Which foam for interior cushions? jephotog Gear & Maintenance 7 08-26-2009 08:35 PM
Cushions for interior TimFowler Gear & Maintenance 28 02-23-2007 01:43 AM
Replacing interior cushions/upholstery heliraf General Discussion (sailing related) 7 04-09-2006 11:00 AM
