Old 11-13-2012
DrB DrB is offline
DrB will become famous soon enough
Keel Fix help
So this year, after the haul and power wash of my Keel, some "barrier" came off. Actually looks like some of it came off some time during the season while the boat was in the water as there was some barnacle growth directly on the lead in a small area. I don't recall hitting anything nor grounding
I have had this happen before in smaller areas, but not this large. I chip away the loose material and it resembles gel coat or filled epoxy paint (white cross section) but underneath there was some red thin paint film. The cipped stuff is about 1/16" (2 mm) thick.
The keel is bolted on, not encapsulated in that respect, but the "plastic covering" is not super well bonded to the lead.
Would like to fix this more permanently than having it keep chipping off in areas. The problem with this location is it is on the leading edge of the keel. Picture here:
Keel Mess
The boat is a Pearson 10M if that gives you clue on what the material is.
My approach to was to:
1) peel the loose stuff back to a clean bonded area.
2) rough up the lead and paint on unfilled epoxy or barrier coat
3) while #2 is tacky, put on thickened epoxy, or epoxy saturated glass cloth and smooth to contour
4) final contour after full set with sanding.
5) thin layer of sealing epoxy.
6) Ablative paint.
If this isn't a good approach, what do you suggest?
Thanks in advance.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
  #2
Old 11-13-2012
Re: Keel Fix help
Doc... the link shows a 'private album' with no image.. better to post the IMG CODE link option, then the pic will show directly in the post.
  #3
Old 11-13-2012
davidpm's Avatar
davidpm is on a distinguished road
Re: Keel Fix help
No picture for me either
  #4
Old 11-13-2012
DrB DrB is offline
Pictures should work now.
Try these. Also I fixed the link.
  #5
Old 11-13-2012
Re: Keel Fix help
Hmmm... I wonder where/when the 'chipping off loose bits' will stop? Once you've gotten under whatever that is I suspect you can just keep going.
Which may be as good a way to go as any.. get rid of all of whatever's there, and start over with your basic plan listed above. I don't think you want to suddenly 'patch' selected areas with cloth and epoxy, I think you'd want a uniform, homogenous coating if that's the way you want to go. The lead looks pretty fair, though, and maybe you just want to prep and paint it.
  #6
Old 11-13-2012
misfits is on a distinguished road
Re: Keel Fix help
I wouldn't glass it. Remove the loose portions, clean up the lead, seal with a barrier coat, fill & fair it
I'm not happy unless I'm complaining about something.
I'm having a very good day!
  #7
Old 11-13-2012
msmith10's Avatar
Junior member, rest old
msmith10 is on a distinguished road
Re: Keel Fix help
Excuse me if it's a dumb question, but why barrier coat a lead keel? Why not take it down to clean lead and apply bottom paint?
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
  #8
Old 11-13-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Re: Keel Fix help
Looks to me like it was faired with Bondo, not filled epoxy. Polyester filler will always fail on a boat eventually. Clean everything off the keel and if required, do it again with thickened epoxy. Since the keel is lead, keep the filler to an absolute minimum thickness.
Edit: Don't put glass fabric on it - just thickened resin.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #9
Old 11-13-2012
RobGallagher's Avatar
HANUMAN
RobGallagher is on a distinguished road
Re: Keel Fix help
I can only tell you what I did.
Strip the keel to bare lead.
Prime it with two part medal primer.
Apply X amounts of two part barrier coat.
Bottom paint.
Never had another problem. Careful in subsequent seasons to stop sanding bottom paint if I could start to see the grey barrier coat.
YMMV.
  #10
Old 11-14-2012
Re: Keel Fix help
My understanding was it gave the filler something to stick to.
You may post attachments
You may edit your posts
Questions about barrier coat on steel keel, and sealing keel joint EricinToronto Gear & Maintenance 1 04-21-2012 09:43 PM
Seafarer 24 swing keel, keel pivot? Sailing qualities? skygazer Boat Review and Purchase Forum 29 03-22-2012 07:45 AM
Rusty spots on keel and hull keel joint Stephane99 Gear & Maintenance 1 04-07-2009 07:39 PM
Swing Keel or Fixed Keel for Caribbean Sailing SailorJim123 Boat Review and Purchase Forum 1 02-04-2009 10:15 AM
Shoal draft keel versus regular fin keel GBurton Boat Review and Purchase Forum 21 08-17-2007 11:33 PM
SEO by vBSEO 3.6.1
