Retrofitting Tiller to Wheel Steering - Page 2 - SailNet Community
 10Likes
post #11 of 38 Old 11-16-2012
Senior Slacker
SlowButSteady's Avatar
Re: Retrofitting Tiller to Wheel Steering
Originally Posted by svHyLyte View Post
Darn I hate the idea of agreeing with SlowButSteady but in this (rare?) instance,....
Don't worry, Lyte. This isn't PRWG -- no one will hold it against you.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #12 of 38 Old 11-16-2012
Brewgyver's Avatar
Originally Posted by cookwithgas View Post
A few more pictures of the parts I collected. Obviously a lot of clean-up work to do. Thanks for all of the great ideas. I will continue with the project and keep you posted on the progress.
So the wheel bore is actually 1.5", not 2"? That would make bushing it down to fit your existing shaft easy, but you still couldn't install it without dropping the rudder.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #13 of 38 Old 11-16-2012 Thread Starter
cookwithgas's Avatar
The actual wheel bore looks to be 1.75". The ID of the donor shaft is 1.5". It splits in half with the removal of bolts. The bushing will have to be a split bushing also - no need to remove the rudder shaft. I'll post pictures as I make progress. First step is to clean up the messy wheel and remove the bolts that hold it together. The wheel is actually "dished" and may fit upside without hitting anything but it will be close. I plan to do a test fit this weekend. The wheel will be installed on the rudder shaft below before I make any decisions on where to install the pedestal. I can still sail with the tiller if a wheel is attached below to the shaft.
cookwithgas is offline
post #14 of 38 Old 11-16-2012
Brewgyver's Avatar
Sorry, didn't see that the wheel was actually split, the condition of it makes it difficult to see that detail. If it will clear, and you have the space to locate the blocks properly (to have the wire rope running to the wheel with no deflection), then it may work out. Going to be a tight squeze! Good luck!
s/v My Sweet Girl!
Atomic 4
post #15 of 38 Old 11-17-2012
blutoyz's Avatar
Good score on this one...it will clean up just fine
blutoyz is offline
post #16 of 38 Old 11-19-2012 Thread Starter
I made a little progress this weekend. See the pictures attached. It looks like it is going to just fit.
post #17 of 38 Old 11-19-2012
blutoyz's Avatar
Like it was made for it
blutoyz is offline
post #18 of 38 Old 11-19-2012
Me at 67
deniseO30's Avatar
Looks good! Is there a chance the hose and stuffing box can be moved down a bit? Only problem I foresee is the angle of the cable to idlers and distance to the pedestal
My last project!
deniseO30 is offline
post #19 of 38 Old 11-19-2012 Thread Starter
Denise you have all the right questions! I considered that and will move everything down if needed. Right now it looks like it will work just fine without hitting the bottom of the cockpit or the big plastic stuffing box top nut. I started work on the shim and so far it looks like it is going to work great.
post #20 of 38 Old 11-19-2012
Me at 67
deniseO30's Avatar
Thanks cook. On my boat the bolt that holds the wheel hub is also the only thing that keeps the rudder shaft from dropping out of the boat!
When you get it all done. you will want to have or make an emergency tiller.
My last project!
Wheel vs Tiller rpearlberg General Discussion (sailing related) 28 02-23-2010 10:23 PM
Tiller or wheel? AllThumbs Boat Review and Purchase Forum 41 09-03-2009 01:56 PM
Converting tiller to wheel steering?! SurfingSS Gear & Maintenance 22 02-10-2009 08:09 PM
Tiller to Wheel Mc51 Gear & Maintenance 18 12-23-2007 02:57 PM
Tiller vs. wheel jadkkd Boat Review and Purchase Forum 34 08-24-2007 09:03 AM
