Winterizing Bilge - Page 2 - SailNet Community
 2Likes
post #11 of 15 Old 11-17-2012
bljones's Avatar
Re: Winterizing Bilge
Lol.
It's 5 o'clock somewhere:
bljones is offline
post #12 of 15 Old 11-17-2012
one thing to add , if you don't take your batteries out take the fuse out for the automatic feature of your bilge pump to prevent it from trying to pump ice (or pink slush) if water does get in and freeze.
cruisingdream is offline
post #13 of 15 Old 11-17-2012
I like the anti-freeze idea. I've used salt in the bilge in the past, turning my fresh water boat into a salty.
SailingSloop is offline
post #14 of 15 Old 11-17-2012
For a keel stepped mast, the garboard plug is an important feature. Since our keel prevents one from being installed in the bottom of the bilge, we remove a thru hull near the bottom of the mast, in which the mast ingress passes on its way to the bilge. Works very well.
Minus 50 degree antifreeze will be overwhelmed very quickly by dilution. Minus 100 and be diluted by half and still protect like minus 50. Remember, these temps are not anti-freeze temps, they are anti-burst temps. They only protect freezing to a much higher temp. Just freezing in the bilge can mess with float switches, etc.
Jeanneau 54DS
Minnewaska is offline
post #15 of 15 Old 11-19-2012 Thread Starter
rwlpatrick's Avatar
good idea thank you
rwlpatrick is offline
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
Winterizing Popsbear Newport 0 11-08-2007 09:33 PM
winterizing timangiel Seamanship & Navigation 17 10-31-2006 03:55 PM
How much winterizing do I need? foxglove Gear & Maintenance 7 09-18-2004 12:22 PM
winterizing the rig jurpo Gear & Maintenance 1 09-11-2003 06:36 AM
