VHF Radio in the cockpit - Page 4 - SailNet Community
 17Likes
post #31 of 63 Old 11-18-2012
Re: VHF Radio in the cockpit
Originally Posted by Ritchard View Post
I realize it's heresy, but I never even look at the compass. I am a GPS man. I know, you respond, "But what happens if the GPS system goes out?" To which I then reply "if the GPS system goes out that probably means all out war, so I have worse problems to think about."
Hummm! If the GPS goes out you should rely on a back up system that you should have, at least the sail you make is not a local one.
Some radio stations come with an integrated GPS, even some hand held radio VHF have one, not to mention watches or cellphones. It is not expensive to have a back up system and everybody should have one.
post #32 of 63 Old 11-18-2012
Lightbulb Re: VHF Radio in the cockpit
If I really needed the compass, I am sure I could switch off the radio and use the one in the cabin.
Okay further to that, would a radio give off enough heat that keeping it in the navpod would kill anything?
Consider... the main real-world problem with electronic nav aids is not the "sky part" but your own on-board part....
We have had enough problems with our "Low QC" Garmin that I would never deleberately compromise the basic compass-and-paper-charts part of the equation, and I do indeed use the chart plotter when under way -- also our trusty old iBook running GPSNavX.
If you feel the need to place magnetic stuff close to the steering compass, just remember to remove it FIRST when it dies. Once you dismount it and put it away, inside the cabin, your steering compass should be fine.
Of course, your compass has been swung and corrected, and a deviation card prepared, right?
And your paper charts are on-board and not more than ten years out of date, right?
And, back to the "door we came in"...... I have done a recent delivery on a boat with a StandardHorizon combo-vhf/ais. It was way cool.
olson34 is offline
post #33 of 63 Old 11-18-2012
No more curry buffets
Ritchard's Avatar
I have:
usually 4 or 5 GPS devices on board
and
No idea when the compass was last swung
and
of course no deviation card.
and a good set of paper charts that I do find very useful for global views when using the chart plotter up close.
All that having been said, my sailing is primarily the Great Lakes version of coastal sailing. It's pretty hard to get really lost.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #34 of 63 Old 11-19-2012
chef2sail's Avatar
We have this Garmin wirelss Mic at the helm and it is invaluable. Even works in the dinghy up to about 1/2 mile away from the mothership. Uses the 25 watt main antanena and gets 10-12 hours battery life ( dpends on transmission usagenormally. Charger is in cabon next to main VHF.
Had a Uniden Wirelss before.
Garmin 010-11189-01
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #35 of 63 Old 11-20-2012
Puget Sound Pounder
kellysails's Avatar
OK,, I think "I" have the absolute coolest remote VHF handheld for the cockpit. The primary cabin VHF is a Simrad RS25 (25 Watt output) and it comes with a Simrad (AHK05) cockpit remote handheld that is tied into the RS25 via BlueTooth! During it's "off" hours it sits in a charging stand. It is crispy clear. It works flawlessly, love it! Simrad is really stepping up IMHO.
Additionally it's DSC button ties into the DSC system on the RS25, very cool.
I should test to see how far it will work from a dinghy, next test on the list.
kellysails is offline
post #36 of 63 Old 11-21-2012
chef2sail's Avatar
Simrad and the Garmin we have are the only wireless available right now
Parkville, Maryland
Our blog-
post #37 of 63 Old 11-21-2012
Puget Sound Pounder
kellysails's Avatar
The Garmin looks great. If I did not have a complete Simrad end to end solution I might go with the Garmin instead. Garmin, IMHO, is making the biggest move in the marine electronics industry. Also I see that the Garmin remote supports three different Garmin cabin based radios. Garmin seems to also be using BlueTooth, which I am a big fan of.
post #38 of 63 Old 11-22-2012
Closet Powerboater
MedSailor's Avatar
Be warned. A good friend of mine was sailing in the Swiftsure race this year and found himself in fog, with shipping and race boats all around, when suddenly his chartplotter, GPS and AIS all died at once. They were all integrated and when one went down it took them all with it.
Personally I prefer multiple stand alone units that do NOT talk to each other. If one dies, it's less likely to take the rest down with it. I am willing to forgo the slick features of integration in favor of redundancy. But then again, I'm probably an anachronism because I've never bought an apple product.....
MedSailor
MedSailor is offline
post #39 of 63 Old 11-22-2012
chef2sail's Avatar
Personally I prefer multiple stand alone units that do NOT talk to each other. If one dies, it's less likely to take the rest down with it. I am willing to forgo the slick features of integration in favor of redundancy-MedSailor
We have Raymarine radar, chartplotter, AIS and ST60 instruments. They are all networked and operate all under stand alone mode also if you wish to conserve power. Just because you network them doesnt prevent you from having them available in stand alone.
Its an advantage to be able to overlay the radar and AIS on the chartplotter in some situations or even have them in side by side orientation on the same screen.
Dave
Parkville, Maryland
Our blog-
post #40 of 63 Old 11-22-2012
I once saw a rig where a speaker and a mike used a bundled cable from a nav-station radio. You had to swing down to the station to change channels, but could otherwise monitor and comm from behind the wheel.
But a hand-held works just find for bridge tenders and harbor masters.
cherev is offline
Tags
dsc , gps , vhf radio
Center Cockpit Versus Aft Cockpit BlueWaterBlair General Discussion (sailing related) 58 03-19-2012 01:35 PM
Getting AM radio stations on VHF Radio L124C Electronics 20 07-01-2010 03:23 PM
Aft Cockpit vs Center Cockpit AjariBonten Boat Review and Purchase Forum 26 11-05-2007 02:53 PM
Center Cockpit vs. Aft Cockpit. badadim Boat Review and Purchase Forum 29 07-19-2007 08:44 PM
Center cockpit or aft cockpit? capsbond Boat Review and Purchase Forum 11 08-09-2006 01:28 PM
