did someone pee in my racor? - Page 2 - SailNet Community
post #11 of 17 Old 11-18-2012 Thread Starter
thedude's Avatar
Re: did someone pee in my racor?
faster
when motoring, where do you like to run your engine? what is your typical water temp at that cruising rpm?
thedude is offline
post #12 of 17 Old 11-18-2012
Tartan 27' owner
CalebD's Avatar
Best book on diesel engines and boating I've read (some of) is: http://www.amazon.com/Boatowners-Mechanical-Electrical-Manual-Essential/dp/0071432388
It is a bit technical but if you really want to learn about your engine and boat's systems this is the book that will save you a lot of money in repair bills.
Everybody has one:
CalebD is online now
post #13 of 17 Old 11-19-2012
chucklesR's Avatar
Check for water every couple of dozen hours of operation. Do the check before you start your engine and it will have plenty of time to separate out and fall to the bottom.
Once it's done that you'll see a clear demarcation between the fuel and the water.
All you really have to do is make sure water doesn't fill the bowl - that would make fuel passage / filtering impossible, what I'm saying is when you drain you don't have to get every last drop, this isn't Maxwell house coffee.
Here's the good news, by opening up your system you've made possible another lesson in diesel maintenance, bleeding the fuel lines.
The clear bowl comes in handy for this too - make sure you never see any bubbles in it.
chucklesR is offline
post #14 of 17 Old 11-19-2012 Thread Starter
thedude's Avatar
thanks everyone. think i'm understanding it's workings a bit more.
to calebd, that book is already part of the library. it's a really good one
thedude is offline
post #15 of 17 Old 11-19-2012
Nobody has mentioned it but the water will appear clear compared to the color of your fuel...If you want to see what you will be looking for... pour some fuel into a glass and add a little water...it will separate out...
Bob142
Desolation Sound
Maple Leaf 48
Any storm in a port...
Bob142 is offline
post #16 of 17 Old 11-19-2012 Thread Starter
thedude's Avatar
thanks bob, i'll try that.
thedude is offline
post #17 of 17 Old 11-19-2012
Siamese's Avatar
But if someone pees in it, you can expect it to be yellow.
Siamese is offline
Racor EX200FG dbruce85 Diesel 8 08-18-2011 08:30 PM
Kudos to Racor bron Diesel 0 08-17-2010 09:01 PM
Racor Filter NautiG Gear & Maintenance 2 12-24-2007 02:12 PM
racor question rperret Gear & Maintenance 8 06-19-2007 01:18 PM
Racor With Too Much Water?? pma_foyl Gear & Maintenance 5 07-12-2004 01:52 PM
