Battery Sizing - am I crazy? - Page 5 - SailNet Community
 17Likes
post #41 of 92 Old 11-22-2012
Re: Battery Sizing - am I crazy?
I suggest two banks of two 6v golf cart batteries for house use, and two 6v golf-cart starting batteries.
If you have the space, which I do on a Morgan 41' OI, use eight 6v golf-cart batteries for the house, wired so serial pairs provide 12v to bus lines. Golf-cart batteries are relatively cheap, and can be found everywhere. Plus you can maintain, test, and trade them out yourself anywhere without any giant hassle.
Lots of juice is important if you have women aboard and an inverter.
cherev is offline
post #42 of 92 Old 11-22-2012
Senior Moment Member
SloopJonB's Avatar
Originally Posted by Minnewaska View Post
Not so fast. I have nearly 20 batteries aboard
Yowza! Don't you think it might be time to consider a gen set?
SloopJonB is offline
post #43 of 92 Old 11-22-2012
Have a genset for sure.
House... 4 batts
Winches... 2 batts
Windlass... 2 batts
Bow thruster.... 2 batts
Main start... 1 batt
Genset start.... 1 batt
Dinghy start... 1 batt
Think I overshot with 20, but 13 still makes the point.
Jeanneau 54DS
Minnewaska is offline
post #44 of 92 Old 11-22-2012
mitiempo's Avatar
House... 4 batts
Winches... 2 batts
Windlass... 2 batts
I am curious how they are all charged! It could have been accomplished with less batteries and good cabling.
Brian
mitiempo is offline
post #45 of 92 Old 11-23-2012
tommays's Avatar
I am pretty sure
You use to have something like this (two group 27s)
They have much better custom hold downs NOW
Two is good just because of things like having TWO bilge pumps on different 24 hour circuits on each battery just in case
And ACR with a small solar control keeps the whole deal happy and I NEVER need to run the motor as are weekend needs are some led cabin lights
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #46 of 92 Old 11-23-2012
Since the house is 12v and the winches, windlass and thruster are 24v (hence the 2 12v batt each), it would be difficult to gang too many together. Have separate banks for the 24v systems allow redundancy. Who would want to get back to the dock and find the thruster is dead.....
To combine some of these would require running some battery cables 20 feet or more. That's not a good idea.
All but the genset start have shore powered chargers that can obviously be powered with the genset too. The main alternator will charge the house and main start.
Jeanneau 54DS
post #47 of 92 Old 11-23-2012
SloopJonB's Avatar
Cap'n Nat & LFH must be up to several hundred RPM in their graves.
copacabana and mitiempo like this.
post #48 of 92 Old 11-23-2012
Beets me how I ever sailed away with oil fired nav and compass lights. Mind you, at only 22 tons I could easily weigh anchor by armstrong and sail up to a dock.
mitiempo likes this.
Capt Len is offline
post #49 of 92 Old 11-24-2012
blt2ski's Avatar
Along with the OP has not been heard from since day one!
maybe over his/her head!?!?!?!?!???
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #50 of 92 Old 11-24-2012
Perfect for your use, I had the same on a 27-footer.
I had two batteries that Costco sold as Marine batteries, i.e. slightly more robust automotive starting batteries, even smaller than the ones you linked to, I think about 60 Ah, $50 each.
Works perfect for day sailing and weekends.
A switch separating the two batteries is good to make sure you always have power to start in the morning.
Run one somewhat empty, but leave enough power to start, then use the other one. IF you run it empty over night, you can still start, and use almost all capacity.
And before the yaddaing by 'battery experts' starts:
Automotive starter batteries (which these are, in essence) DO survive the running REALLY low on occasional weekend use very well, for practical purposes. They last years.
Shorten theoretical battery lifetime by 50%, and you still have several years of use, and are out of $50.
As proven by people who have to jump-start their cars.
Originally Posted by chartscharts View Post
All,
My CAL29 is in need of new batteries. The existing ones are shot and won't hold a charge. I wanted to solicit opinions about downsizing drastically.
My existing batteries are a bank of two of these: Trojan EV8D, 12Volt, 220AH@20hr, batteries. They are big and weigh a gazillion pounds a piece. More than I can easily remove myself, a big disadvantage.
My needs are modest. It primarily needs to start my Farymann A30, single cylinder, 10HP diesel. I have the usual running lights and house lights and VHF radio.
My sailing habits are almost exclusively day sailing. 2-3 times a year (on good years) I'll take it out for an overnight. I could use battery powered camping lanterns on those even, since it's not very often.
So I think I might be able to drastically downsize, allowing for easier and cheaper maintenance and replacement. Going to something like two of these:
[retarded sailnet policy counts your link as one I may not post; removed]
Am I crazy? What am I not thinking of?
-Charts
Navigator Wannabe is offline
Battery Fuse Sizing - How, What...? Maine Sail Electrical Systems 28 09-21-2011 07:14 PM
Battery cable sizing micheck General Discussion (sailing related) 0 06-10-2011 04:50 PM
Battery Cable Sizing labatt Gear & Maintenance 11 02-19-2009 11:15 PM
Sizing battery cables scosch Gear & Maintenance 9 11-09-2007 01:35 AM
Sizing a Battery Charger for Windlass Battery btrayfors Gear & Maintenance 9 04-11-2007 12:43 AM
