Old 11-18-2012
Bambolera is on a distinguished road
hydraulic autopilots
I have a Westsail 32 and want to install a reliable autopilot. Is there any reason why a good linear hydraulic ram system couldn't be attached directly to the tiller. If a proper installation were made, the hoses could be routed through water-tight deck fittings and the pump could be mounted below. A permanent mounting near the back of the tiller, with a large pin that can be pulled to quickly disconnect the system, shouldn't be that difficult to engineer.
Has anybody heard of this being done?
You may post attachments
You may edit your posts
autopilots endevour Electronics 11 04-11-2010 07:42 AM
autopilots mychaos Gear & Maintenance 12 06-24-2008 01:11 PM
SEO by vBSEO 3.6.1
