Cutting above waterline hole in boat - Page 2 - SailNet Community
 5Likes
post #11 of 13 Old 11-20-2012
Barquito
Barquito's Avatar
Re: Cutting above waterline hole in boat
I need to cut a 1" hole above the waterline for the exit fitting.
Is it a good idea to try to get the discharge above the heeled waterline?
Valiant 32
Barquito is online now
post #12 of 13 Old 11-20-2012
Getting the hole above the heeled waterline is not necessary. Just be certain that you put a loop in the discharge hose with the top of the loop above the hole and secure the hose. This is the arrangement I have on my B27. I made the mistake of not securing the loop and it fell while heeled and before I knew it,the cabin sole was underwater. It took a few panic stricken minutes to find out what happened and remedy the situation.
PS: Hole saw definitely.
Gramps is offline
post #13 of 13 Old 11-20-2012 Thread Starter
Puget Sound Pounder
kellysails's Avatar
The primary bilge line leaves via the stern, and I will do the same with the secondary. And I will put in the highest loop in the line that that I can fit in.
As for cutting the hole: (Hellosailors' idea wins)
I'm going with the laser, awesome! Hopefully I won't nick my LPG line
kellysails is offline
Cutting Access Hole in Stainless Steel Diesel Fuel Tank Ajay73 General Discussion (sailing related) 42 12-27-2011 08:28 PM
Small hole completly aft at waterline Bene505 Gear & Maintenance 24 03-09-2009 12:21 PM
cutting access hole xort Gear & Maintenance 27 01-04-2009 05:33 PM
Cutting a hole in the deck dawnhoff Gear & Maintenance 12 07-04-2008 09:47 AM
Cutting through hole NautiG Gear & Maintenance 12 01-08-2008 07:18 AM
