Like Tree6Likes
  #1
Old 11-19-2012
Rusty123 is on a distinguished road
Hardware Store Epoxy?
I need to make a couple minor repairs to my boat, one to patch a small hole in the side of my cockpit locker exactly the size of a 1/8" drill bit (not sure where that come from ).
Anyway, can I get away with using the two part epoxy that the hardware store or wally world sells? I know that if I was doing major work, the West Systems product woudl be cheaper, but I just need a tiny amount.
In other words, is all epoxy basically the same thing?
  #2
Old 11-19-2012
Stumble is on a distinguished road
Re: Hardware Store Epoxy?
Rusty,
No all epoxy isn't the same, and every formulation will have different properties, work differently, and cost differences.
The real question is if hardware store epoxy is suitable for your needs. Without knowing what product you are talking about I couldn't begin to give you an answer. Other than generally for this you would want a thickened epoxy, where the thickening agent does not absorb water. Silica of some sort is ideal, but there are a lot of other options.
Greg Rubin
Titanium Salesman
  #3
Old 11-19-2012
deniseO30's Avatar
Lies about her age
it's ok, it just won't hold up to sunlight like gel coat.
  #4
Old 11-19-2012
Brent Swain is on a distinguished road
Been using it for decades and never had a problem with it. No epoxy is all that good for UV
resistance.
Brent Swain, Yacht designer, Builder, and author of "Origami Metal Boatbuilding"
  #5
Old 11-20-2012
jameswilson29's Avatar
Senior Smart Aleck
jameswilson29 is on a distinguished road
No, the West Marine epoxy costs twice as much because it is marine-grade quality. Plus you get a high-quality, genuine plastic pump with it.
Marine grade describes the willingness to spend twice as much due to the fear of sinking many miles from shore. They have perfected a magical formula, as secret and unique as the special sauce on a Big Mac, which resists salt water, ultraviolet rays, and common sense.
Ordinary manufacturers of products are incapable of fully understanding the marine environment and prefer to design fragile, weak, inferior products in mass quantities which will then unravel, fall apart and disintegrate in the presence of motion, salt water and sunlight.
Beersmith, oysterman23 and Squidd like this.
  #6
Old 11-20-2012
This is a huge misconception that a lot of people have. Most of the manufacturers that I deal with don't take any markup at all because something is going into the marine world (heck we try to shave costs for marine use). There are often real and fundamental differences between a marine part and a standard part, but these differences are not often immediately aparent unless you know exacally what to look for.
One of the best examples is in light fixtures btw. Lowes sells tons of low cost brass light fixtures, so why should anyone buy one from West Marine for double (or more) the money? Simply because West requires their products to be admiralty brass which is an alloy specifically designed to resist de-zincification. It is harder to work with, has a more expensive metal mix, and is used in small quantities than 'common brass' that is about 40% zinc. For most applications having a high zinc content isn't a problem, but put that part on a boat in salt water, and you can almost watch it disolve.
Standard hardware store epoxy like the Devcon sold by Ace has a tensile strength of 1,500psi. Which is pretty strong. But compare it to West System with a tensile strength of 7,900psi, or roughly 5 times stronger. You may it need that strength in every application, but that isn't the same thing as the two are the same.
And those pumps are awsome. Until you have spend days cutting uncored epoxy out of a keel trunk with a chisel, because someone mis-measured the hardner, you can't know how nice it is to know that so long as they use the pumps they can't get it wrong.
davidpm likes this.
Greg Rubin
Titanium Salesman
  #7
Old 11-20-2012
Senior Smart Aleck
Originally Posted by Stumble View Post
This is a huge misconception ...
Do you have any objective, third-party test results that prove that?
I am not so gullible to accept what a salesman or a manufacturer claims to be true.
  #8
Old 11-20-2012
overbored's Avatar
overbored is on a distinguished road
is it a locker drain hole or it had a bracket mounted on the inside of the locker at one time. most any thickened epoxy can be used to fill the hole, the issue with epoxy is the UV exposure. it will turn color and degrade in time. it will not match the gelcoat if that is what you have on the surface. if it is gelcoat then you could use a gelcoat repair kit and fill the hole with the matching color.
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
  #9
Old 11-20-2012
Those are the physical properties that the manufacturers claim. I don't know about the hardware store stuff, but lets assume it is accurate. The West Systems is ASTM certified to those numbers, so yes there is third party verification of their claims.
Greg Rubin
Titanium Salesman
  #10
Old 11-20-2012
Senior Smart Aleck
Your argument is specious because the ASTM cert (if it exists) does not compare it to the brands available at hardware stores.
Why would I assume your figures are accurate? (I already told you I don't trust what salesmen tell me, unless verified by independent objective third-party proof.)
I bought 3M epoxy resin and hardener at Lowes. It appears the same product is rebranded by West Marine as their epoxy.
I don't believe there is any difference, other than the price and the pump, unless you prove otherwise.
You may post attachments
You may edit your posts
Is any epoxy paint a good epoxy paint? SVTatia Gear & Maintenance 8 05-19-2011 09:57 PM
BBQ implements - or - How I tested stainless steel at the hardware store Bene505 Cruising & Liveaboard Forum 5 03-01-2010 02:22 PM
Sealing Deck Hardware, and Epoxy over Teak 1970Columbia34 Gear & Maintenance 3 08-24-2006 03:34 PM
SEO by vBSEO 3.6.1
