Rubber vs. Sanitary hose - SailNet Community
 1Likes
post #1 of 13 Old 11-19-2012 Thread Starter
I noticed that Don Casey's books recommend using rubber hose as the default for pretty much all water applications (except potable). He hardly mentions the white sanitary hose, except where odor is a big problem.
However, virtually all of the non-potable water hose on my boat (waste, drains, etc.) is the white heavy duty sanitary hose (Trident Vax XHD). Seems like pretty stout hose -- should replacement with rubber hose be on my long term upgrade plan?
Rusty123 is online now
post #2 of 13 Old 11-19-2012
pdqaltair's Avatar
Re: Rubber vs. Sanitary hose
First, none of the hoses are actually rubber; they are all synthetics (nitrile, neoprene, urethane, , PVC, EPDM) chosen to fit the specific application. The only thing to broadly avoid is clear vinyl.
Practical Sailor did a review of sanitation hoses. Yes, they are different from water/exhaust hoses and fuel hoses.
Trident 102/101 and Shields Poly-X are the 2 top picks. But the full answer requires reading the article. This post gives a few bits:
http://sail-delmarva.blogspot.com/20...sy-button.html
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #3 of 13 Old 11-20-2012 Thread Starter
But am I running some sort of risk with sanitary hose instead of rubber hose? If so, what?
post #4 of 13 Old 11-21-2012
Seņor Member
PorFin's Avatar
Rusty,
I think that Casey's recommendation is based on the premise that there's no need to spend the extra dough on sanitary hose when plain old heater hose will work.
If the sanitary hose is sound and not leaking, then I think you can safely move your worries elsewhere.
Do take the time to read the article PDQ posted, though
PorFin is offline
post #5 of 13 Old 11-21-2012 Thread Starter
That would make sense, except when I priced hose for my cockpit drains (1 1/2"), rubber house was about 3 times more expensive than the white stuff.
I signed up for a Practical Sailor subscription, but it looks like I need my first I issue before I can access back issues.
post #6 of 13 Old 11-21-2012
Chastened
Ajax_MD's Avatar
Sail Delmarva: The Easy Button
PDQ-
When you say to avoid clear vinyl hose, are you including those clear hoses that are specifically rated for potable water? Some are completely clear, and some have some sort of reinforcement in a cross-hatch pattern on them.
If you are referring to these, why avoid them?
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #7 of 13 Old 11-21-2012
pdqaltair's Avatar
Originally Posted by BubbleheadMd View Post
PDQ-
Certainly not a safety issue for potable water. Where I don't like seeing them--and have--is on holding tank vents (they permiate within a few months based upon testing) and engine lines (I've seen them for cooling water and fuel vents).
I prefer polyethylene tubing for water. It lasts longer and does not contain plastisizers (taste). But there is nothing wrong with using a material within its rating. Where flexibility is needed (shower hose) it may be the only practical choice.
chef2sail likes this.
post #8 of 13 Old 11-25-2012
No more curry buffets
Ritchard's Avatar
Any guidance as to what material would make a better tank vent line? I have the cross-hatched clear stuff.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #9 of 13 Old 11-25-2012
Seņor Member
PorFin's Avatar
Ritchard,
If you want to keep the stink at bay longer, go with sanitary hose.
PorFin is offline
post #10 of 13 Old 11-26-2012
Rusty, the only drawback to white sanitary hose is that it is DAMNED EXPENSIVE. Other than that it is superior to rubber hoses in every way. You've got the good fortune to have all "gold plated" hose in that boat, the last thing you would want to do is throw it out and replace it with the cheap stuff.
hellosailor is offline
sealing sanitary hose? 71Irwin32 Gear & Maintenance 11 08-10-2012 02:55 PM
Problem routing sanitary hose Barquito General Discussion (sailing related) 1 05-22-2011 08:26 AM
Quick-connect hose fittings for bilge hose? cghubbell Gear & Maintenance 1 06-03-2010 03:45 PM
Spa flex PVC hose for sanitation hose TrojanSailor Gear & Maintenance 6 07-22-2007 08:51 PM
