Like Tree6Likes
  • 1 Post By Silvio
  • 1 Post By Gramps
  • 1 Post By SloopJonB
  • 3 Post By Silvio
  #1
Old 11-21-2012
Silvio's Avatar
Battered and Bruised
Silvio is on a distinguished road
That's my story and I'm stickin' to it
So often aboard my expensive little hole in the water I scratch my head and say to myself "self, now aint that odd."
Well, the other day was just one of those times. I consider myself pretty good at keeping an eye on things and maintaining my boat in good order, so it was with a little surprise that I went to check the ATF fluid and could not find the dipstick in its usual location, e.g in the fill hole.
To my surprise the dipstick was lying under the prop shaft and showed a bit of corrosion as though it had been there awhile. The trans was dry of fluid (at least low enough to not register with the dipstick in). This is the point where I say "self, now aint that odd."
I check the trans fluid every third or fourth trip out, and fortunately typically only motor a few hundred yards before the puffy white things are out and the motor is off. I know the prop still rotates and I am hopeful that the fluid was merely low and not dry, and that sailing with the trans in neutral doesn't spin the gears. In any event I topped off the fluid, ran through forward and reverse, pulled in and out of the slip a few times, and all appears well. Still, for the life of me can't figure out how the dipstick got to be out in the first place. I rarely have to add any fluid so typically I never let go of the stick. I pull it out once to wipe it, then reinsert to get a reading then tighten it in place to finish.
Man, gettin' old is tough! Gonna have to ask the Admiral to help me keep an eye on the dipstick, would hate to lose another one.
PCP likes this.
SV S.S.R.I
It's my happy pill
  #2
Old 11-21-2012
Gramps is on a distinguished road
Re: That's my story and I'm stickin' to it
When did you first notice it was missing?
Silvio likes this.
  #3
Old 11-21-2012
PCP PCP is offline
That's a good story but unless you believe in Elves you got to get an explain for how that happened. I am waiting
  #4
Old 11-21-2012
azguy is on a distinguished road
Funny story, I've seen them blow out on their own with high horsepower muscle cars, not sure about low horsepower boats.....
  #5
Old 11-21-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
I went to check the oil in my wife's van a few years ago and found the dipstick lying on top of the engine. The tip had rubbed against a pulley until it was ground down to the add mark.
I told my wife it must have been the kid in the gas station - I mean, it couldn't have been ME, right?
She pointed out that we use self serve gas pumps but I still think she must have used full serve when I wasn't around.
I'm also stickin' to it.
Faster likes this.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #6
Old 11-23-2012
Silvio's Avatar
I must have pulled it at some point and set it down without paying enough attention to what I was doing. It is very unusual for me to do such a thing, but that is all I can come up with. I am willing to believe elves snuck in and sabotaged it though.
SV S.S.R.I
It's my happy pill
  #7
Old 11-23-2012
msmith10's Avatar
Junior member, rest old
msmith10 is on a distinguished road
What were we talking about?
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
  #8
Old 11-23-2012
Silvio's Avatar
Dipsticks, and the things they misplace.
j34035, msmith10 and SloopJonB like this.
SV S.S.R.I
It's my happy pill
You may post attachments
You may edit your posts
Tell me your story CraigMiller1 General Discussion (sailing related) 10 10-15-2011 03:46 PM
I want to know your story CraigMiller1 Introduce Yourself 4 10-13-2011 10:46 PM
The story so far chamonix Introduce Yourself 2 06-28-2010 02:33 PM
Here is story for you.. Giulietta Gear & Maintenance 18 11-29-2006 05:55 PM
SEO by vBSEO 3.6.1
