Is condensation a problem if I insulate/line the hull interior? - SailNet Community
 1Likes
  • 1 Post By Brent Swain
post #1 of 10 Old 11-23-2012 Thread Starter
So I ripped out the mildew stained carpet that lined the hull in my v-berth and I need to replace it. For about the same cost as replacing the carpet, I can buy a couple western red cedar 4x4's, run them through the table saw and have a nice liner for my hull.
If I leave the space between the strips and the hull open, or if I pack some sheet foam in there first, am I asking for condensation and mildew?
peterchech is offline
post #2 of 10 Old 11-24-2012
Rogue Musician
TheTardis's Avatar
Hi Peter! I asked the same question a few weeks ago and have had some excellent responses to it. I recently also ripped out the nasty carpet in by cabin and v-birth. I cleaned the fiberglass, applied several coats of mildew resistant primer, a layer of reflectix, and finished with wood. I have actually documented the whole process in my photo gallery. The thread is called winter moisture control under the liveaboard forum. And my gallery can be found under my signature. PM me if you have any specific questions. Good luck!
Brass Belle
'78 Pearson 30, #1099
TheTardis is offline
post #3 of 10 Old 11-24-2012
Re: Is condensation a problem if I insulate/line the hull interior?
How did you attach everything especially the wooden top layer?
thanks
i_amcdn is offline
post #4 of 10 Old 11-24-2012
72 C&C Corvette
CorvetteGuy's Avatar
Glass in a few stringers to screw the new wood to that leaves an air gap between the hull and the wood
CorvetteGuy is offline
post #5 of 10 Old 11-26-2012 Thread Starter
I guess that air gap layer, ESP if its full of insulation, worries me that it might trap condensation and become a mildew trap...
post #6 of 10 Old 11-26-2012
SchockT's Avatar
If you use Armaflex sheets for insulation you shouldn't have mold. Armaflex os mold resistant, and non absorbant. If there is no way for moist interior air to contact cold bare hull you should not get condensation.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #7 of 10 Old 11-26-2012
+1. I used volara because a supplier of mine carries it, but arma flex is even better I suspect.
Sent from my SGH-I747M using Tapatalk
Jgbrown is offline
post #8 of 10 Old 05-13-2013
GrahamO's Avatar
Reviving an old thread here but I'm having trouble sourcing Armaflex in the US. Do you know wher I can buy it?
Thanks
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #9 of 10 Old 05-13-2013
SchockT's Avatar
Try you local HVAC suppliers. Armaflex is commonly used in that industry.
Hull#101
SchockT is offline
post #10 of 10 Old 05-13-2013
Yes condensation will flow down that space like a river. Closed cell foam in full contact with the hull is the only way you will eliminate condensation there.
Minnewaska likes this.
Brent Swain is offline
Wildwood Lamps launches coastal-motif lamp line - World Interior Design Network NewsReader News Feeds 0 03-02-2012 07:10 AM
carry on a/c condensation problem jasonr575 Gear & Maintenance 1 08-08-2011 12:54 PM
Boat Hull Condensation RIYachtBroker General Discussion (sailing related) 2 11-05-2009 12:41 PM
Interesing condensation problem - galley sink tonybinTX Gear & Maintenance 10 03-17-2008 07:14 PM
interior hull movement jeneaton1 Gear & Maintenance 2 05-23-2004 06:31 PM
