Normal battery water usage - SailNet Community
post #1 of 10 Old 11-25-2012 Thread Starter
pdqaltair's Avatar
Yup, searched it, but couldn't seem to find what I wanted. I've used about 4 oz./month lately on my group 27s; all used about the same amount and they are identical.
What is the normal range of water usage? I'm certain this varies a good deal with use--storage vs. cruising, size of bank vs load, charging method, whether charger adapts to temperature changes--but all answers are of interest because...
a. Readers will have boats of many sorts and many practices.
b. I operate in different modes too, as most of us do.
My current problem is that I have both solar and plug-in charging, and for the first time I'm using both. Ordinarily, I only use the plug-in if I'm with the boat, other wise relying on the solar regulator to avoid dueling chargers; however, I'm testing dehumidifying equipment which is requiring me to leave the shore power on.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #2 of 10 Old 11-25-2012
Maine Sail's Avatar
Re: Normal battery water usage
4 oz per month is quite a lot of water usage and enough to lead to diluting the electrolyte rather quickly. This becomes a catch 22 scenario where they suffer and die more rapidly. They need water or they'll die but more water dilutes the electrolyte and also causes death...
I suspect your batteries may be sulfated and coming up to "voltage" quickly. When batteries become sulfated the current can't penetrate the plates well and a surface charge builds. The voltage of the battery rises quickly and stays there until the charger or controller goes into float. With healthy batteries it should take the batteries a long while to come up to "absorption" voltage. Once batteries approach 14.2V + they can begin boiling off water (temp dependent). The faster they come up to voltage, and are held there, the more water is used.
In warm climates this gets exacerbated when a voltage like 14.4 - 14.6V is used at temps over 80F.. Anytime your batts get over 80f the voltage should ideally be dropped to compensate for the battery temps.
What solar controller and what battery charger do you have..?
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 10 Old 11-26-2012 Thread Starter
pdqaltair's Avatar
This controller (Morningstar "Prostar" 12 Volt 15 Amp Solar Panel Charge Controller w/ Digital Display) with 2 x 85w panels feeding 3 x group 27 batteries. Yes, it is set for wet cells. No, I do not often see charging voltages over 14V and never higher than 14.2V.
The batteries are not old (8-2012) and have not been flat or dry. It is only very recently that I have noticed the water dropping, just the last month, as I checked them before I started leaving shore power on. I suspect the Freedom unit may actually be the problem, as the charging voltage is higher now. Previously I used < 2 ounces per month. IS it possible that the 2 chargers simply don't play well together?
I'll need to check the electrolyte gravity next visit. My understanding is that the normal gravity varies somewhat with the application (cars being lower than deep cycle). I'm assuming that in this weather about 1.285 SG is expected at full charge.
post #4 of 10 Old 11-26-2012
" IS it possible that the 2 chargers simply don't play well together?"
In theory, I think, what "should" happen is that when one charger sees voltage from the other, it will say "OK,batteries are full now, I can drop back to float charge" and if they both do that, you'd wind up with a failsafe where the chargers would NOT charge properly and the batteries would be getting charged way too slowly/gently.
In practice...most every charger is a "too damned clever" smart charger these days, and I'd hate to guess what might be possible, depending on what each one sees in what stage of the charging cycle and how it decides to reset itself. They're just not intended to live and play with ANY other kids in the same sandbox.
To find out what is really happening, I think you'd need to buy a dmm that has a data logging function, or an RS-232 output to store data on a PC (serial port required) and then actually watch the charging voltages to see what mischief the silicon kids were getting into.
While you're docked, can you just disconnect the solar side and see if the Freedom is charging properly when left by itself?
"The only good silicon life form is a DEAD silicon life form"
[Star Trek episode, probably an homage to Will Rogers]
hellosailor is offline
post #5 of 10 Old 11-26-2012 Thread Starter
pdqaltair's Avatar
[QUOTE=hellosailor;953182]
I think that is the next plan.
post #6 of 10 Old 11-26-2012
Maine Sail's Avatar
[quote=pdqaltair;953220]
PDQ,
There are no issues with multiple controllers or charge sources except that the controller, charger or alternator reg with the highest voltage wins. When a controller, regulator or charger senses a higher voltage than they are set for they simply shut off or discontinue charging until the voltage falls to their set point where they again begin "voltage limiting". Even with two identical units both set to 14.4V one will always be set slightly higher than the other causing the other to shut down first. Of course if the source with the higher voltage has the lower current and you need more current the two will "cycle" back and forth. Usually best to set the source with the most current availability to have a slightly higher absorption voltage.
It sounds to me like you have a charge voltage set too high or the shore charger is perhaps set to an automatic equalization. You may also have a defective battery?
In six years, on my own wet cells, I have used perhaps 8 oz per battery in total. They've only needed water three times in six years or about every other year. Most of my customers use a similar amount with similar situations except for my customers with Rolls batts & the larger 6V's which do tend to use more.. Perhaps some hydrocaps might be in order?
You really need to monitor the charging voltages to see what is going on. Dropping absorption back to 14.2V will decrease the water usage.
This video might help put it into perspective?
______
post #7 of 10 Old 11-26-2012
aeventyr60's Avatar
all good but explain the circumstances of your battery water usage mainsail. I'm in the tropics, avg daily temps in the 90's. Putting in about 100 Amps per day on a 480 amp 6v golf cart battery house bank...New batts in Septemeber, and can advise on a 3 month cylcle here, but my historic usage quite a bit more then yours....Sure our usage is different, even in NZ my use was higher, similar to yours 6 months, maybe the temperature a bigger factor?
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #8 of 10 Old 11-26-2012
Maine Sail's Avatar
Yes heat causes more water to be used and can also lead to over charging if not temp compensated correctly. 6V type batteries also use slightly more than a typical 12V "deep cycle" battery will..
Our batteries rarely if ever get above 80F and are usually more in the 60-70F range and this helps minimize water usage.
Our sailing season averages about 7 months for us (April 15 to late Nov) but I do use the boat nearly daily. Not all of those days see deep cycles though. Our bank has been sized so that our average DOD is just 30% of capacity. Still 4 oz per month, per battery, is a LOT of water for a 12V battery to be taking.
I am beginning to suspect some contamination in the batteries perhaps from non-distilled water or perhaps external contamination when the caps were removed. Errant metals in the electrolyte can cause a "poisoning" of the negative plate which can then reduce the gassing point as low as 2.2V per cell or 13.2 volts if bad enough. This may be the problem....
______
post #9 of 10 Old 11-26-2012
the pointy end is the bow
erps's Avatar
We have 2v type batteries (six of them in series) and go thru a few gallons a year. I think battery type has something to do with it and that it's more important to keep track of a change in water consumption rather than comparing water consumption between battery types.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #10 of 10 Old 11-26-2012
aeventyr60's Avatar
I had a steady use of a liter and a half every 3 months for the old 6v batteries, interesting to see how the new Trojans hold up.
Water Miser Battery Caps mikeedmo Gear & Maintenance 1 08-08-2013 05:02 PM
Battery water level edwmama Gear & Maintenance 12 10-16-2012 11:40 PM
Cruising GPD water usage average Vitesse473 General Discussion (sailing related) 26 07-05-2008 04:42 PM
Hot Water Heater Usage PBzeer Gear & Maintenance 38 01-21-2007 09:31 PM
Water Miser Battery Caps mikeedmo Gear & Maintenance 2 09-21-2006 06:56 AM
