Mainsheet Salsa - Page 2 - SailNet Community
 2Likes
post #11 of 22 Old 11-27-2012 Thread Starter
Over Hill Sailing Club
smurphny's Avatar
Re: Mainsheet Salsa
That's a great idea Greg. I never considered using a partial cover. Wouldn't it tend to slip or bunch up? I guess if I sewed it along the length, it would be ok. Could even run a line of stitching with machine to make sure it stays put.
smurphny is offline
post #12 of 22 Old 11-27-2012
Re: Mainsheet Salsa
You want to minimize as much as possible any disturbance of the amsteel core. So no stitching except where absolutely necessary.
Follow the instructions at http://www.samsonrope.com/splicing-p...UG2012_WEB.pdf for the smooth cover installation. It really only takes a few minutes to do, and can save a ton of money. You can use these same instructions for any cover, but I like the ice because it is built with a draw line already in it. Old stripped poly line will work just as well, though it takes a bit more work to bury the core back in.
Greg
Stumble is offline
post #13 of 22 Old 11-28-2012 Thread Starter
smurphny's Avatar
Re: Mainsheet Salsa
Thanks. I looked for an instruction sheet on the NE Rope site but they don't seem to have one. I'm probably going to go this route.
smurphny is offline
post #14 of 22 Old 11-28-2012
I don't discuss my member
zz4gta's Avatar
Re: Mainsheet Salsa
80' won't go to the top of the mast and back down to the deck. I buy 80' of halyard for my 25 footer.
You'll need 55-60' of amsteel, then just splice an empty cover on the end that's 50' long, overlapping 10'. Splice a shackle on the end, whip it, done.
That being said, what type of sheaves do you have at the mast head? Any chafe points? How important is creep to you? SK75 (type of dyneema) creeps a bit. Requiring you to re-set the halyard. An alberg 35, probably doesn't care much about creep.
Another simple option, just get a blended core like VPC, MLX, or any other option out there. Technora and vectran also make good halyards. Are you using dacron sails? If that's the case then use a blended core halyard, save your money. The sails are going to stretch much more than your halyard.
I'd also spec out a 5/16" halyard for your boat. 1/4" is very small for a 35 footer.
Salsa line - I have it for a traveler line and have seen it used for jib sheets on winches. It does surprisingly well on winches. Only issue is that it might flatten in a cam cleat. I had a problem with Apex doing that on my boat. Salsa will work great on a mainsheet.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #15 of 22 Old 11-28-2012 Thread Starter
smurphny's Avatar
Re: Mainsheet Salsa
Not using the Salsa for a halyard but mainsheet for which it is plenty long. Actually 80' would be long enough for a halyard..just. 90' is about right. I am going to keep my eye out for 7/16" VPC for a new halyard. I'd use 3/8" Dyneema for a main halyard. Dyneema/Amsteel DOES stretch over time but not under immediate stress to any great extent. The new 90 series has almost no stretch (but is wicked expensive). I'll likely make up a main halyard from 3/8" Dyneema with a partial cover as suggested by Greg. Although the 1/4" has plenty of strength, I'd still go with something bigger. The older boats like mine with large mainsails are VERY sensitive to any loss of halyard tension. That's why I have stuck with the wire halyard thus far. I'll be keeping the wire halyard ready to go back on:-) The sheave is, of course grooved for wire but seems smooth enough so that it will not abrade the line. I'll probably rout out a new profile if a rope halyard works out but, I'm not going to burn that bridge until after a season using the Dyneema.
smurphny is offline
post #16 of 22 Old 11-28-2012
zz4gta's Avatar
Re: Mainsheet Salsa
I wasn't suggesting salsa for a halyard, sorry for the confusion.
Back to the halyard,
Your I dimension is 40.5' ALBERG 35 sailboat specifications and details on sailboatdata.com So to go up the mast and down to the deck once, you need 81'. Call it 82 if you're cleating at the mast and 90 if you're using a mast mount winch and actually want a shackle attached to the other end.
You also need to measure the hypotenuse of a triangle, couple more feet, and if it's blowing, you'll have deflection from the breeze when you're trying to plug in the headsail. Not a straight line = more length. Point is 80' ain't gunna cut it. Not even close, and 90' would also be short imho.
BTW - your mainsail isn't exactly big at 275 sf.
zz4gta is offline
post #17 of 22 Old 11-28-2012
Re: Mainsheet Salsa
Zz,
The discussion was about using it for a mainsail halyard, so you should be using the P dimension which is 35'. Of course you need the tail, but this is very boat dependent, ie where the clutches are, how things are run. For this boat that would mean 70' plus tail.
The length of the headsail halyard is =square root of (I^2+j^2)+I. For the Alberg 35 this would be 42+40=82' plus whatever tail you want.
Smurphy,
You can certainly go with a larger size, but I can't see a point to it. The SK-75 has roughly the same stretch as wire, and while there is some misconception on the Internet about this, there is no appreciable creep in dyneema line when used for halyards. Creep is measured over the course of years, not hours or even days, and takes significant (as a percentage of breaking strength) long term load to even be an issue.
The major issue people see with stretch in dyneema lines is actually their sails stretching, or the line slipping through clutches (this is why the covers are so important), not actual elongation of the line itself.
Brewgyver likes this.
Greg
Stumble is offline
post #18 of 22 Old 11-28-2012
zz4gta's Avatar
Re: Mainsheet Salsa
The original post was using salsa for a mainSHEET.
For the main halyard, the 35' dimension is a start, but I'm assuming he'll need a knot or a splice at one end to attache to the sail, then wraps around a cleat and a winch if it stops at the mast like this one
70' won't cut it. 82' is pushing it.
I can measure a triangle. I was suggesting he builds a halyard to real life requirements as opposed to I or P measurements.
My mistake on referencing a jib halyard dimension, you're right the main won't need quite as much, but still way more than 70'.
zz4gta is offline
post #19 of 22 Old 11-28-2012 Thread Starter
smurphny's Avatar
Re: Mainsheet Salsa
Actually, the measurement is shorter than mast height. The m/m is from top of where shackle attaches to sail to the sheave, which is not quite mast height. The actual dimensions for the halyard are closer to 35' each way.
If you do some research, you'll see that these old design sailboats have very long booms and large mains as compared to the more modern headsail-dependent rigs. Not only do they have long booms but most of the time the sails were roached out to squeeze out the maximum sail area. The large mains actually present a problem with excessive weather helm. I just recut a sail taking out all the roach and then some and shortening the foot so as to have a heavy, less weather helm prone sail. I may shorten the boom eventually.
When I replace the halyard, it'll be 90'+ Wish I had a nice windlass like that!!!
The actual mast measurements for anyone else with an A35, measured on boat:
Deck-mast top-39'-3"
Deck to lowest main track-48"
Deck to halyard winch- 41"
Deck to halyard cleat- 24" or 12"
smurphny is offline
post #20 of 22 Old 11-28-2012 Thread Starter
smurphny's Avatar
Re: Mainsheet Salsa
Originally Posted by Stumble View Post
Zz,
Smurphy,
You're absolutely right. I tend to over-do things like this. 1/4" would be fine and a lot cheaper. The price on Amsteel has really gone up. I don't remember paying nearly as much a couple of years ago when I did the lifelines.
smurphny is offline
A better way to run the mainsheet.... MedSailor General Discussion (sailing related) 5 02-25-2012 03:44 PM
mainsheet Packrat Gear & Maintenance 5 08-08-2008 08:00 AM
Boats Salsa Sue & Larry Cruising Articles 0 12-31-1998 07:00 PM
Fresh Salsa Sue & Larry Cruising Articles 0 12-31-1998 07:00 PM
