Mainsheet Salsa - Page 3 - SailNet Community
 2Likes
post #21 of 22 Old 11-30-2012
tap
Re: Mainsheet Salsa
There is a nice line stretch calculator here http://l-36.com/line_stretch.php
It has a number of different types of line and gives you the stretch for the load you have for each one. Wire is very low stretch, more so than amsteel. Helps to see how much a larger or more expensive line changes thing.
Straight Amsteel-blue is the clearly the best in terms of $$ per stretch. Even cheaper lines end up costing more because you need to get a much larger diameter line to have the same stretch.
tap is offline
post #22 of 22 Old 11-30-2012
Re: Mainsheet Salsa
Tap,
I have a similar chart for breaking strength, and again amsteel comes out the clear winner on a per price basis. Even though its expensive for its size you get so much extra strength you can almost always down size it at least once from other stuff. And with cover splicing you can get whatever size you need on the working end for ease of use.
Greg
Stumble is offline
A better way to run the mainsheet.... MedSailor General Discussion (sailing related) 5 02-25-2012 03:44 PM
mainsheet Packrat Gear & Maintenance 5 08-08-2008 08:00 AM
Boats Salsa Sue & Larry Cruising Articles 0 12-31-1998 07:00 PM
Fresh Salsa Sue & Larry Cruising Articles 0 12-31-1998 07:00 PM
