Lewmar Folding Wheel - SailNet Community
 1Likes
post #1 of 13 Old 11-26-2012 Thread Starter
tdw
Super Fuzzy Moderator
tdw's Avatar
I'm intent on going for a folding wheel. Whatever negatives there may be are for mine far outweighed by the positives. Cockpit access an obvious plus but also there is the ability to go for a slightly larger diameter wheel.
Now i've had a good look around but one question remains unanswered. How much space is required behind the wheel in order to fold the thing ?
Our current wheel is 900mm (36"), hoping to up that to 1000mm (40") .
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is online now
post #2 of 13 Old 11-26-2012 Thread Starter
tdw
tdw's Avatar
Re: Lewmar Folding Wheel
As per usual I'm realising that I didn't think this question through. Of course the answer can only be accurately determined by the height of the cockpit seat in relationship to the centre of the wheel.
Nonetheless presuming most helm seats are about the same height perhaps someone can give me an idea.
― Terry Pratchett.
tdw is online now
post #3 of 13 Old 11-26-2012
Tim R.'s Avatar
I happen to know that 40" wheels fit in the following boats with plenty of room to spare to fold.
CS 36T
Ericson 35-3
Caliber 40
They really do not take much room and I would be very surprised if you did not have enough room. I would guess that at the center-line you need about 8-10 inches of clearance. I am sure someone here with better geometry skills can calculate it based on the wheel diameter. The folding sides each fold in 1/4 of the wheel. Fit a box inside the diameter and then measure from teh side of the box to the arc of the wheel at center-line.
Also note that the wheel is slightly dished to accommodate the folding. This is good as with the wheel deployed it usually gives a little more room to walk around in "T" shaped cockpits. If you have a wind vane, you may have to slightly modify your setup.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #4 of 13 Old 11-26-2012
Look at the hinge points.. they create two segments out of the wheel 'circle'.. draw a straight line through the rim hinges and spoke joints and scale it to the wheel diameter to be sure...
Faster is online now
post #5 of 13 Old 11-26-2012 Thread Starter
tdw
tdw's Avatar
Thanks people.
Treilly .... I think you are almost certainly correct. 99.99% so.
Fast I will check that.
but ... my error was in thinking the wheel max diameter of the wheel would be at seat level which it quite obviously isn't. As TR notes, with the wheel tapering away from max diameter as it falls I should have little or no problem even with a bigger wheel.
Wind vane will not be an issue with our setup.
This pic shows why I'm an idiot for worrying in the first place.
You'll notice if you look carefully that there is a vertical hatch/flap under the seat that drops down. This is to facilitate fitting and use of emergency tiller. In worse case scenario dropping this flap would enable the wheel to fold.
btw ... on another somewhat related note ... I saw in another thread on this topic quite a few suggestions re simply using the Edson quick release nut and removing wheel altogether. One couple we knew did this very thing but they also carried a tiny wheel they he then fitted in case of emergency. Looked odd in practice but seemed to work.
― Terry Pratchett.
tdw is online now
post #6 of 13 Old 11-26-2012
jimrafford's Avatar
I have the 40" on our cs. At it's widest point in the middle of the folding section it's maybe 1'. Really opens the cockpit for stern access and folds very quickly. Also you will never be scrambling to put the wheel back on when you know what hits the fan.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #7 of 13 Old 11-26-2012
Tim R.'s Avatar
I just measured my 40" wheel and it requires 10" clearance at the midpoint. Looking at your photo I would guess you need 6-7".
Tim R.
1997 Caliber 40LRC
Tim R. is offline
post #8 of 13 Old 11-26-2012 Thread Starter
tdw
tdw's Avatar
Jim
Jim,
Not the folded thickness that concerned, rather the space required to swing the folding section. Nonetheless I'm pretty certain its sorted.
Andrew B
― Terry Pratchett.
tdw is online now
post #9 of 13 Old 11-28-2012
No more curry buffets
Ritchard's Avatar
Another thought, if it was tight, and you were set on getting one, could you not turn the wheel so that the folding part is up, fold one side, rotate the wheel 180, and fold the other side, then turn the wheel another 90 to it's normal position? It seems it would only take an extra moment.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is online now
post #10 of 13 Old 11-28-2012 Thread Starter
tdw
tdw's Avatar
Thanks for that .... Obviously not going to be a problem. The space is nowhere near that tight.
Ricthard .... good point really, that would seem a solution if space was really tight but in reality that space would need to be so tight that it would hard for anybody to actually stand behind the wheel.
― Terry Pratchett.
tdw is online now
Folding prop help ltgoshen Gear & Maintenance 36 06-19-2013 06:30 PM
You own a Lewmar Folding Wheel Crewm8 Gear & Maintenance 6 04-04-2012 01:06 PM
Lewmar folding wheel...any reason why not? Mimsy Gear & Maintenance 21 07-12-2011 12:11 PM
Lewmar Folding wheel Hub LakePirate Gear & Maintenance 2 08-19-2009 06:00 PM
Folding Destroyer Wheel sailortjk1 Gear & Maintenance 12 08-07-2006 03:38 PM
