rework or leave alone the old wooden rudder - SailNet Community
 2Likes
  • 1 Post By cookwithgas
  • 1 Post By Faster
post #1 of 7 Old 11-27-2012 Thread Starter
During my overhaul last winter I didnt get time to address the old wooden rudder that came with the boat so I gave it a light sanding and a few coats of polyurethane. Now I'm going after some of the projects I couldnt complete before last season started. My plan is to sand it down thouroghly. Then use body filler to smooth all the bumps and bruses including a quarter size knotch on the trailing edge. Once it is smooth I plan to cover it in 1 layer of fiberglass and lots of resin. After its good and smooth I will paint it then add bottom paint. My reasoning for this is to increase the strength and integrity of the rudder. I would also like to be able to leave it in the water with the rest of the boat. Last year every time I was done sailing I would unpin it and lift it down below so it would be out of the weather. Its got to weigh all of 50 pounds and kind of a pain in the ass because of it being awkward to move it about. I would appreciate comments on how I will be doing this or the products being used as I'm always looking for new products and techniques. Please see the attached pictures.
Cheektowaga-20120506-00483.jpg   Cheektowaga-20120506-00484.jpg   Cheektowaga-20120506-00486.jpg   Cheektowaga-20120508-00500.jpg   Buffalo-20111110-00167.jpg
ABH3 Boyer is offline
post #2 of 7 Old 11-27-2012
cookwithgas's Avatar
Re: rework or leave alone the old wooden rudder
Just my 2 cents - I replaced my wood rudder BUT it was a solid hunk of wood and I needed a kick-up rudder. Yours looks like it kicks up already so the wood should work. I would not use body filler. West systems has a powder like material you can add to the epoxy the gives you a body filler type result. Use this instead. Here is what my original rudder looked like on my Mac 22:
I fabricated a rudder using HDPE from a cooking supply manufacturer - 1.5" thick! It was fairly heavy but worked and looked great. Here are a few pictures:
The first part of this video shows it in action:
ABH3 Boyer likes this.
cookwithgas is offline
post #3 of 7 Old 11-27-2012
sailortjk1's Avatar
Body filler? as in bondo?
Is there any sign of rot? If so, I would be using Penetrating Epoxy.
Courtney is My Hero
sailortjk1 is offline
post #4 of 7 Old 11-27-2012
One of None
deniseO30's Avatar
ABH your rudder looks to be made out of teak. poly resin and cloth won't stick. Even epoxy doesn't bond well to teak. If you use acetone to clean the oils off the newly sanded surface. most varnishes will stick. It's all pointless if the rudder is in the water 24/7 though.
My last project!
deniseO30 is offline
post #5 of 7 Old 11-28-2012 Thread Starter
sounds like I should load it up with poly and keep taking it off
post #6 of 7 Old 11-28-2012
Yes.. any bright-finished wood rudder will last much longer if rigged to easily lift off the pintles and store on board between uses. Look into easy-to-use locking mechanisms vs keeper pins so the rudder doesn't lift out on you at an inopportune moment..
This product is an easy install.. it mounts on the transom above the upper pintle/gudgeon assembly.. the rudder will slide by the clip during installation, but the clip has to be pressed in to allow the rudder to lift off. Inexpensive enough, but also easily fabricated DIY, I'd think.
http://www.westmarine.com/webapp/wcs...7#.ULZLxoWGGUc
Faster is offline
post #7 of 7 Old 11-28-2012
Your plan is a good one. That's precisely what I did to my Wayfarer rudder (teak ply). Fill voids with epoxy loaded with colloidal silica, cover with a layer of epoxy fibreglass.
If the rudder is to be left on, you need to either paint it or apply the customary 7 layers of spar varnish to protect the epoxy from UV. Polyurethane is not suitable for this application.
I think after doing this, you should still take it off, though.
MarkSF is offline
Can I buy a boat in the USA and leave it there? redunculous Boat Review and Purchase Forum 13 11-27-2010 09:55 AM
How to leave. wind_magic General Discussion (sailing related) 29 09-19-2009 09:25 PM
Solar Panels - Repair/Rework - info needed paul43 Gear & Maintenance 4 09-01-2008 04:18 PM
paint for wooden rudder Mick Young Gear & Maintenance 1 05-19-2007 08:06 PM
How to leave database bbhazelton Announcements and Suggestions Box 0 02-16-2007 12:30 AM
