Worn holes for the Winch Pawls - Page 2 - SailNet Community
 1Likes
post #11 of 21 Old 11-28-2012
bljones's Avatar
Re: Worn holes for the Winch Pawls
I misread the title- thought it said "wormholes."
That would explain where all the beer disappears on our boat.
It's 5 o'clock somewhere:
bljones is offline
post #12 of 21 Old 11-28-2012
I have a pair of Lewmar 40 two speeds which I clean and lube every 5 years or so; they are from the mid-1980's. This summer I dropped a part overboard whilst cleaning and lubing on the boat.. I ordered the exact replacement part from P2 marine:
Lewmar Winch Parts
Check the diagram on their website and make sure yours are put together properly. The palls should not fall out, but then again....
Seaduction is offline
post #13 of 21 Old 11-28-2012
Apologies. I thought you were referring to the lewmar 40. Minnewaska linked you to the correct page on P2 marine website for the Lewmar 8. Ordering info is shown on the page and I was happy with my service from P.
post #14 of 21 Old 12-01-2012
tap
I've seen online where someone had drilled new holes for the pawls after theirs wore out like yours have. But that winch had didn't have the two raised areas in the drum where the pawls went. It was solid all the way around so there was a place to drill two new holes. It doesn't look like you have space for a new hole.
Maybe you could get a some rod or tube and make a new holder for the pawl, then drill out the old holes in the drum to fit the outer diameter of the tube. Sort of like a helicoil insert for a stripped out screw hole.
tap is offline
post #15 of 21 Old 12-02-2012
Ordering replacement parts is soooo simple. (I suppose they may be sold out however)
P2 Marine, at least have a look.
post #16 of 21 Old 12-02-2012
I would only weld and drill as an absolute last resort and only by a real professional machinist. This is stuff that can hurt you.
Jeanneau 54DS
Minnewaska is offline
post #17 of 21 Old 12-02-2012
tap
Not much chance finding parts for these winches. P2 doesn't have winch drums for early lewmar winches, made from 1982 to the early 90s. These look like earlier lewmar winches made in the 70s. P2 doesn't even carry parts for these.
Here a thread on SA about winch repair. Some pictures of redrilled pawl holes.
tap is offline
post #18 of 21 Old 12-02-2012
Uhh... I bought parts for my 1985 (27years old) Lewmars from P2 just this past summer. OP could at least verify their lack of parts with a simple phone call. I'm only suggesting an easy fix. If they are actually devoid of such pieces for the winch in question, then nothing lost.
post #19 of 21 Old 12-02-2012
tap
1985 is newer than 1982, when Lewmar came out with new winches. The OP winches look like pre 1982. But maybe there is a old winch drum on a shelf for 30 years no one has thought to look for.
It's quite possible that a winch drum, if one could be located, won't fit. One these old winches they didn't always make the parts interchangeable. Stuff like pawls, springs, bearings, circlips, etc. would all be the same. But the final machining of the castings would be done custom for each winch to make everything fit correctly. They didn't have the accuracy of modern CNC mills back then. Those holes for the pawls were probably done by "hand" after the spindle and drum were already mated.
tap is offline
post #20 of 21 Old 12-02-2012
Another possibilty. Have a local machine shop open the holes slightly by simply plunging in a slightly larger end mill. Then find a wire EDM shop (or eMachine.com) to have a pair of slightly oversized pawls made. They can cut hardened stainless to very precise dimensions using that process.
Gary H. Lucas
GaryHLucas is offline
Worn through to gelcoat? i_amcdn Gear & Maintenance 0 08-09-2012 10:43 PM
Lewmar 25 Winch Pawls towen999 Gear & Maintenance 2 03-30-2012 03:05 AM
Mystery winch pawls SV Pohadka Gear & Maintenance 11 08-28-2011 08:49 PM
Which pawls for a Lewmar #10? jarcher Gear & Maintenance 2 08-22-2010 10:49 PM
A Worn Shaft Log Tom Wood Gear and Maintenance Articles 0 10-06-1999 09:00 PM
