What Halyards go to the Masthead? - SailNet Community
post #1 of 7 Old 12-05-2012 Thread Starter
I know I need a main and jib halyard going to the masthead sheaves. I also have a spinnaker, topping lift, and storm trysail that needs to be hoisted. Which of these halyards should go to the last two(one sheave aft, one forward) remaining masthead sheaves?Thanks in advance.
Pat
lizardheadone is offline
post #2 of 7 Old 12-05-2012
GeorgeB's Avatar
Re: What Halyards go to the Masthead?
You didn’t mention the size and type of boat that you have. Jib and main halyards go through the masthead sheaves. Some people use the “spare” aft sheave (you have a four sheave set-up or two?) for the main topping lift. Although, this is not the only way to rig a “topper”. The spinnaker needs to be on a swivel block mounted above the headstay and will not be routed through a masthead sheave. Storm Trysail? You use the main halyard for this but you may want to invest in a separate track for ease of deployment. Are you thinking about a storm jib? If so, the halyard will be on its own block mounted below the baby stay. The baby stay will be mounted opposite of the head card of either a third reefed main or your Trysail. The purpose of that is to match the loads lower down on the mast.
GeorgeB is offline
post #3 of 7 Old 12-05-2012
jarcher's Avatar
On my 30 foot sloop I recently replaced the mast. I went from four halyards (main, port jib, starboard jib, spinnaker) to just three (main, port ib and starboard jib).
The two forward halyards each can hoist a head sail or spinnaker. They are used interchangeably for head sail hoisting and the spinnaker.
Oh, they all go to the top.
Helios
Scampi 30 MK-IV
jarcher is offline
post #4 of 7 Old 12-05-2012
SchockT's Avatar
Spinnakers are meant to fly outside the fore triangle, so the halyard should fly from a point above the forestay, whereas a genoa halyard exits below the forestay. Also, spinnaker halyards fly from a floating block to allow for the multi directional loads they see. A genoa halyard runs on a fixed sheave that only works on the fore-aft axis, and side loads can result in excessive friction, chaffing and even halyard jams. You may get away with it in light winds, but it could be problematic when the wind pipes up and you really want to get the chute down! You can use a spin halyard for a genoa, but you should NOT use a geny halyard for a chute.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #5 of 7 Old 12-05-2012
jarcher's Avatar
Nah, its fine, check this out:
Jim's Scampi 30 MK-IV Site - Helios | Demystifying Scampi Sailboats!
Scroll down a little to see the mast head picture. The cage on the front of the mast there allows either halyard to be pulled forward or to either side with very little friction. This is standard Kenyon design for an Evelyn 32, a nice light, fast sport boat. I use this rig on a Scampi 30 and it works quite nicely.
Helios
Scampi 30 MK-IV
jarcher is offline
post #6 of 7 Old 12-05-2012
jarcher's Avatar
Some better pictures here...
Erection Day pictures | Jim's Scampi 30 MK-IV Site - Helios
Helios
Scampi 30 MK-IV
jarcher is offline
post #7 of 7 Old 12-05-2012
SchockT's Avatar
Yeah that looks more like a spin halyard exit. Does the halyard clear the forestay hardware without chaffing when using it for a genoa halyard? I would pay extra attention to the cotter pin side. You should be ok since you are essetially using spin halyards for genoa not vice versa.
Hull#101
SchockT is offline
rope & wire halyards vs all rope halyards kjango Gear & Maintenance 20 03-02-2013 03:16 PM
WiFi and VHF of the masthead micheck Gear & Maintenance 6 01-10-2011 04:49 AM
Where to run the halyards jarcher Racing 11 04-21-2010 11:24 AM
masthead box BigZ Ranger 2 04-04-2010 12:57 PM
Halyards sail-away Gear & Maintenance 2 06-11-2001 04:49 AM
