Lewmar maintenance - SailNet Community
post #1 of 11 Old 04-03-2004 Thread Starter
Lewmar maintenance
I have a pair of older Lewmar #16 msingle-speed self-tailing winches. They have a bottom cover held in by a large spring-ring.
Can anyone advise how to disassemble?
Thanks,
Rob
lisasailor is offline
post #2 of 11 Old 04-03-2004
Lewmar maintenance
LEWMAR 16 WINCHES:
No tools are required to service a curent Lewmar winch. Unscrew the top cap with your fingers to remove the needle peen drum and provide access to the centre stem. To mount winch, remove the needle peen drum for access to the deck fitting holes.
Pre-Ocean Series Winches require Manual 6 (March 85).
Ocean Series requires Manual 7 (May 85).
Service Manual: http://www.lewmar.com/pdfs/Winch_Service_Manual.pdf
Parts Manual: http://www.lewmar.com/pdfs/Vol10_WEB.pdf
Lewmar Head Office - Lewmar Ltd
Southmoor Lane, Havant, Hampshire, PO9 1JJ, England
Tel: +44 (0)23 92471841 - Fax: +44 (0)23 9248 5720
Email: info@lewmar.com
Web: www.lewmar.com
In Florida:
Lewis Marine Supply
217 SW 32nd Court,Ft Lauderdale, FL,33315, USA
Tel: 954 523 5403
Email: sales@lewismarine.com
Web: www.lewismarine.com
In Canada:
Paynes Marine Supply Group
1173 N Service Road W Unit D1
Oakville, ON, L6M 2V9, Canada
Tel: 905 825 0200 - Fax: 905 825 0202
Email: sales@paynesmarine.com
HTH
Gord
GordMay is offline
post #3 of 11 Old 04-05-2004
Lewmar maintenance
I had the same problem a few months ago. Info on the newer lewmar winches can be found on their website, but not for older models. Went to a local rigging shop that has some lewmar stuff, and he just happened to have some sheets of paper describing how to get apart the self-tailing ones: The top part of the self-tailing mechanism unscrews counter-clockwise - you may need to take a piece of wood, hold it against the piece of metal that leads the line into the self-tailing mechanism and give it a rap with a hammer to loosen it. Make sure you knock it it the proper direction! After that, it''s a piece of cake.
Thermal is offline
post #4 of 11 Old 11-02-2009
old Lewmar winch
Hi, Thermal,
Do you still have the sheet of paper describing how to disassemble and service your old Lewmar 16 winch? Can you describe how to remove it for servicing? Ours is on a Catalina 36, probably the original from 1982, and we've tried unscrewing it from the underside of the cabin top. We can't get one of the 5 nuts off the bolt. We'll hacksaw it off, if we have to, but ... then what??
Thanks for any help you can give me.
See photo at: flickr. Add a dot-com and a slash, and then: photos/kathysheehan/4067662830
CaptKathy is offline
post #5 of 11 Old 11-02-2009
CaptKathy:
I have an old lewmar service manual with an exploded view of the #16ST. I could fax it to you. Let me know the number.
Shadowjack1
shadowjack1 is offline
post #6 of 11 Old 11-03-2009
Lewmar winch manual
That would be great. Can you fax it to: (number removed) Thanks!
post #7 of 11 Old 11-03-2009
Lewmar #16 ST
Captkathy
Your fax machine does not answer.
I'll try latter this pm.
Bill
post #8 of 11 Old 11-03-2009
ratchet gear on Lewmar winch is toast
Thanks very much Bill.
Looks like our ratchet gear is completely toast. Given the age of this winch (almost 30 years) and the paucity of repair parts, I think we're in the market for a new or used one.
Very helpful to have.
PS: I am going to try to delete or edit the fax phone number in my previous post in case some spam bot picks it up.
post #9 of 11 Old 03-20-2011
Lewmar 16ST parts?
I need a ratchet gear from an old Lewmar 16 winch, either single speed or two speed. Vintage 1980, likely from the early standard or the holdfast series. I have lots of inquiries out via Internet, wonder if anyone has an old one lying around collecting dust?
JToben is offline
post #10 of 11 Old 03-30-2011
contact Mike a Winch Spares in UK. I am in Ohio and I have worked with him several times. He is fast, reliable, reasonable and knowledgeable. Email him your problem and he will likely have the exact part you need.
winchspares.com
Winch Spares
sales (at) winchspares.com
Last edited by Catherine2245; 03-30-2011 at 07:29 PM. Reason: to show email address
Catherine2245 is offline
Servicing older lewmar winch zeilfanaat Gear & Maintenance 16 04-04-2016 10:04 PM
Lewmar Hatch Panel - Adhesive parvenu Gear & Maintenance 6 01-06-2010 06:18 PM
older lewmar winch parts windancer1 Gear & Maintenance 2 09-11-2009 06:10 AM
Lewmar port screens bista Gear & Maintenance 0 08-15-2001 06:33 AM
engine maintenance training psemme Gear & Maintenance 2 04-27-2001 05:59 AM
