Bright work buffer - Page 3 - SailNet Community
 2Likes
post #21 of 29 Old 03-17-2013 Thread Starter
Re: Bright work buffer
Cockpit table is under the bimini and has a sunbrella cover when we're not there. Finish should last a while and future years probably only require a top coat on the boat. I'll gather some pics.
Jeanneau 54DS
Minnewaska is offline
post #22 of 29 Old 03-18-2013
Asleep at the wheel
jimgo's Avatar
Have you read this? Polishing Varnish
or this?
Departments
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #23 of 29 Old 03-18-2013 Thread Starter
or this?
Departments
Thanks. Certainly confirmed my thought that it really needs to dry longer. I wasn't thinking of 2 weeks. It will take me the rest of this week to get the last coats applied and I splash next week, so I have a feeling the table is going back on without buffing this season. Maybe it will be a rainy day buffing project.
Jeanneau 54DS
post #24 of 29 Old 03-18-2013
chucklesR's Avatar
So, being a table - which gets some use after all - why not go with a poly or urethane finish?
You could even topcoat it with them, then buff.
chucklesR is offline
post #25 of 29 Old 03-18-2013 Thread Starter
I've used about everything and was a big fan of Bristol Finish. I do not want to apply a poly on top, although, I know others are happy with it. The day will come where it will need to be sanded down and redone. I would like to be able to avoid a full strip, like it did this past time, to insure I know what I'm applying over.
Whatever will be on it, we keep placemats in the center bin of the table and there are four integrated cup holders. I'm not too worried about damage, but it can happen. If anything the subtle wear will eventually take the dust particles out.
I think my final coat is going to require a clean room approach! Tear down, vacuum, wipe down walls, tape over the air duct (which has always been off anyway).
We'll see. It's looking real good so far, its just a matter of how nutty I want to get.
Jeanneau 54DS
post #26 of 29 Old 03-18-2013
Asleep at the wheel
jimgo's Avatar
WANT to get? At this point, isn't "how much nuttier I'm going to get" a better way to phrase that?
BTW, I'm almost as bad.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #27 of 29 Old 03-18-2013
blt2ski's Avatar
Originally Posted by chucklesR View Post
I've got to admit that I've never thought of polishing my brightwork, but I'm absolutely fascinated by the idea, especially of someone else doing it.
Pic's, before and after - I mean really, is it worth it for varnish that will be exposed to weather?
Only if you want at some point in your life to be totally anal retentive with the idea of really bright bright work!
Otherwise, for me, a quick sand down then 5-6 light coats seems to work well. maybe some day tho............
before, during after pics would be good. Malcolm would like them for the owners forum in the hints and tips area too!
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #28 of 29 Old 03-18-2013 Thread Starter
I didn't really photo document, but I will get some pics off my phone. I have a pic of the table on the boat from a couple of years ago, but not really a good 'before'.
Jeanneau 54DS
post #29 of 29 Old 04-22-2013 Thread Starter
Originally Posted by blt2ski View Post
before, during after pics would be good. Malcolm would like them for the owners forum in the hints and tips area too!..
Pics in post 10 here
Perfection Plus
I ultimately decided not to use a buffer. I experimented with it around coat #7, but while it completely removed all imperfections, it really wasn't as glossy as straight clar gloss varnish.
I did get crazy OCD on making a dust free environment for the final coat.
Jeanneau 54DS
Bright work smillinjack Gear & Maintenance 16 09-26-2010 01:44 AM
Bright-work refinish with Honey Teak, advice? mrybas Gear & Maintenance 14 07-30-2010 09:33 AM
Bright work finishing ebs001 Gear & Maintenance 10 01-21-2007 07:55 PM
Painting over old bright work??? wildcard Gear & Maintenance 2 12-02-2006 04:15 AM
Buffing the Hull - Random Orbital Buffer? offline2004 Gear & Maintenance 4 01-24-2006 04:25 PM
